hi guys. im thinking of replacing an old aftermarket dvd player /sterio /head unit that doesnt work. i was thinking of replacing the speakers if they dont work and all speaker wire because i dont know if its all connected.instead of mucking around looking to see if it works i was thinking of just buying it all. i have seen i think big thinck amp or sub wire that has been cut when the last owner might have had a sub in there. it has an old original looking amp thing in the boot still, is it worth getting a new one. i would like to know what i need to purchase to redo the whole thing but only the basics. i dont have to much money to spend lots on it.
https://www.sau.com.au/forums/topic/449289-r32-gtst-new-audio-everything/
Rip all the old wiring out and inspect them. If they look dodgy at all or you're not comfortable with them, run new wires.
That's the sensible option.
You know most people would start a thread and ask for more advice.....
  • 4 weeks later...
Put new wiring through!!
When you're forking out the cash for a full system, might as week spend the extra $200ish for new wiring..
When I did mine, kicker were selling full wire kits for about $150 (with a range of different gauges depending on how crazy you want to go).. The wire kits even come with a 10-15 year warranty, which (If I remember correctly) covers your system for any blowouts...
I'd suggest it getting it all professionally installed though!!
    • One of the things that never seemed right was the handbrake. Put in some nice new Project Mu shoes. We figured the rears were out, so why not. We're right there. My handbrake never worked well anyway. Well, this is them, 15km later. 67fdcf94-9763-4522-97a4-8f04b2ad0826.mp4 Keen eyes would note the difference in this picture too:   And this picture: Also, this was my Tailshaft bolts: 4ad3c7dd-51d0-4577-8e72-ba8bc82f6e87.mp4 It turns out my suspicions that ne side of the handbrake cable was stretched all along were pretty accurate, as was my intuition that I didn't want to drop the tailshaft to swap them on jack stands and wasn't entirely sure about bolt torque. I have since bought the handbrake cables which have gone in. I'm very glad that I went to my mechanic friend who owns an alignment machine to get an alignment before the track day, because his eyes spotted these various levels of "WHAT THE f**k IS GOING ON HERE?". Turns out the alignment wasn't that bad, considering we changed the adjustable castor arms out for un-adjustable castor arms, and messed with the heights. Car drove pretty good with one side of the handbrake stuck on, unbleedable rear brakes, alignment screwy, and the tailshaft about to go flying and generally being a death trap waiting to happen! (I did have covid) (I maintain I adjusted the handbrake correctly, but movement caused shennanigans and/or I dislodged the spring on the problem side somewhat, or god knows what). G R E G G E D
    • Very interesting, im not sure how all those complications fit in to running a haltech instead of a stock ecu but I'm starting to think I'm a bit out of my league.
    • I just put 2 and 2 together. This is a Neo converted R32. The Neo ECU (in concert with the R34's AC controller) runs the AC quite differently to how the R32 ECU and AC controller do it. If you just drop it all in, it won't work. There is some tricky wiring required, including changing to the pressure switch that the Neo controllers want to see. I don't know what it is, because mine was done by a guru. It was a year or so after I did that transplant before he worked out what needed to be done.
    • Don't assume the AC relay signal from the ECU is +, some models including Stagea use an earth trigger.
    • Hey good to see you on the forums! Haha Considering this cars past with electronic issues I am leaning towards it being a wiring fault somewhere in the engine bay. When testing the ac relay in the fuse box there was no earth trigger. I am probably going to try "bench test" the compressor by giving it direct ground and power to see if i can hear the ac clutch click otherwise I will be pretty sure I have a dead compressor. If it does work then I will be tracing some wiring it seems.
