Ok Ive got an R33 GTST with an RB26DETT transplant. The motor is stock with the normal exhaust and intake upgrades and an electronic boost controller set at 12psi. (Dynoed at 225rwkw). I have stuffed a turbo and i'm in the process of deciding to replace the stock turbos or upgrade to something like some low km secondhand N1 turbos.
My questions are do i need to install a Power FC if upgrading turbos? (i assume i would???) What power could i expect if i do upgrade to N1s and a power FC???
If anyone would like to make suggestions it would be appreciated! Also if anyone has secondhand turbos for sale let me know!
Thanks guys.
https://www.sau.com.au/forums/topic/44929-turbo-upgrade-questions/
A standard internals RB26 with R34 GTR N1 turbo's tuned via a Power FC with apropriate support systems and other upgrades made 332 rwkw.  I am sure there are others with better results around. :cheers:
SK;
can you tell us what the whole engine package entailed in this case, paticularly the 'support systems and other upgrades'?
Thanks
Hi guys, I will try and answer your questions in one go;
The spec was;
264 @ ~9.5 mm cams (I think they were Jun, I didn't fit them)
Adj Cam pulleys (they were definitely Jun)
Split dumps and 2.5" engine pipes (my design)
3.5" exhaust (my design)
2 X standard GTR cats (I had them)
Sard 650 cc injectors (standard ones ran out at 290 rwkw)
Nismo fuel pressure regulator (not really required, but the standard one was screwed)
Bosch 044 fuel pump in tank
Power FC with boost control kit
2 X Pipercross POD's with heat shield and large ambient air induction (my design)
2 X RB20 AFM's (I had them too)
OS Giken twin plate clutcch (with flywheel)
Greddy 600 X 300 X 100 intercooler (Nengun)
Alloy I/C pipework (my design)
Oil cooler and remote filter (Earls)
Winged, doored and baffled sump (my design)
Tuning, tuning, tuning (not by me)
Hope that answered your questions :(
    • Ok glad you clarified on the frenchy’s options , I was worried about if my oem hoses would fit the new compressor or not if I just bought the bracket/compressor kit ,  didn’t realize they also sold a larger full conversion kit. Hmm may just go oem in that case then to make it easy only because I plan to sell this car to upgrade to a 32 GTR or 34 GTT.
    • Sorry Duncan, I didn't get a notification for the replies.  Thanks for responding!  It's a full Android device, but does allow you to use CarPlay/AA as well.  This is the one I bought from NaviRS on AliExpress: https://www.aliexpress.com/item/1005006368602668.html?spm=a2g0o.order_list.order_list_main.111.59aa1802JDzQ0E - the 2K 8G-256G CAM variant but it seems to have gone up by £170 since I bought it!  My purchase was £307.14.   It's not the fastest thing in the world but performs perfectly adequately.  It stays on standby unless I disconnect the battery and let it power down, then it's just a fairly standard Android bootup time from cold.  The DSP Equaliser is very nice and made the standard stereo system sound pretty decent compared to the stock screen.  Perhaps I can take a video of it when I get a sec. It *allegedly* supports the reverse camera, but I'm yet to get that working.  It has options for reverse cam (a camera unit can be bought separately) or 360 cameras (also bought separately).  To be fair it doesn't seem to detect that the shifter was put into reverse but I'm working on a theory about this as well.  At the moment I'm going without which is a bit annoying considering the car is an absolute canal barge but so far I haven't caused any damage I'll grab a picture of the wire I'm missing later today when I can get outside.  My theory, by the by, is that not only is the head unit different, but the CANBUS network has different signals for the different years.  I think this because I have a spare AC panel from a newer Infiniti G37 (as opposed to my Nissan panel) which wouldn't control anything except the volume when I had it wired up with the stock system.  I'm going to throw it back in and see if the screen will respond to it.  I've just ordered an arduino CANBUS module so I can have a look at the signals going around the car and see if I can spot anything.  I'm thinking if I can work out what it's expecting vs what it's getting I might be able to translate and relay the signal back but so far just a theory anyway. I also found this on my travels, so far the only one that specifically matches my car: https://www.aliexpress.com/item/1005002822934280.html?spm=a2g0s.imconversation.0.0.33433e5fgttovi If you look at the picture of the before, it has the card reader slot, and the picture of the head unit is exactly the same as the one pictured in my original post.  I asked if they sell the cables separately but sadly they won't.  I didn't want to just buy this one because it's a super old Android version and only dual core - likely slow as hell.
