Hi all, I am having trouble with my S2 R33 GTST, have had a look around the forums but so far nothing has really helped.
The problem is when the car gets warm it just dies (can crank it over but wont fire) and wont start again until cold.
When the car is cold it starts first turn of the key and will drive around and wont miss a beat until its warm and then wont start again.. The problem has been occuring for a little while now but thought it was fixed after unplugging the ECU (Nistune) it didnt happen for about 150k's (the car doesn't get driven very often)
Have swapped the cas and afm (Z32) for known working units and it didn't make a difference, plugs look alright and the Splitfire coilpacks are only around 8 months old also unplugging the coolant temp sensor doesn't do a thing.. Car also drinks a fair amount of fuel round about 300 Kilometers to a tank on 98.
Could this be an issue with the tune? any help would be greatly appreciated cheers.
  • Like 1
https://www.sau.com.au/forums/topic/449301-r33-dies-when-hot/
Does it crank slow ? Like a flat battery ? Could be your starter motor solenoid sticking/faulty, a friend had an old hilux that would start fine when cold but once up to running temperature, if he turned it off he wouldn't be able to start it for a few hours till engine was cool again.
Hey guys sorry for the delayed reply..
Answers to previous comments..
defari- temp gauge says abit under half when it dies
blind_elk - Wont start if i give it any throttle just floods it and runs like shit when it eventually fires haha..
Lrs94- Nah doesn't crank like a flat battery cranks like normal
Kane_R32 - Fuel pressure is good after car shuts off
mlr- Where abouts are connections on chassis and block?
UPDATE- Turns out the cas i tried turned out to be an RB20DET one plug was the same but apparently the timing is different? And i ran the car the other day and when it got to temperature it didn't shut down and even took it around the block and let it sit at home idling and didn't die? :wacko:
    • Personal experience. Those f**kers burn. And are actually a PITA to put out. Next time I walk down the back, I'll snap a photo of what the inside of the bonnet looks like when that thing ignites. PS, powder fire extinguishers are useless on that stuff too as it's fibrous and when it ignites, it starts to pull apart. And you end up just blowing powder through a sieve effectively.   Like the big thing is, if it's fire resistant, it's job is to stop what burning? The METAL above it? It's just to try keep heat off the bonnet paint work.
    • Oh man, sorry, $60.00000000... 😛
    • That's more or less what he meant. What it really means is that you do not have to go full crazy on the build. Don't need the best oil pump, expensive rods & pistons, big cams, etc. You can upgrade whatever you want instead of using stock level items, but you don't have to. Having said that - any time an RB is opened up, if anything is getting replaced, I think the opportunity should be taken to do all the sensible upgrades. Pistons, rods, pump, etc.
    • February update 🙂 We managed to get the very last 1/18th "Extra Scale" cars stock available from bookstores in Kyoto. These are actually the last ones and will not be restocked again! Hachette Collections Japan have not decided on a release date for these or other models in the series, so for the time being these are all there are available new.  These are showing up on Yahoo auctions at inflated prices already (especially the Celica and NSX) so get yours now at a very reasonable price before they disappear! Stock quantities: NA1 Honda NSX - 1 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1990-na1-honda-nsx 1973 Toyota Celica LB 2000GT - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1973-toyota-celica-lb-2000gt 1968 Mazda Cosmo Sport - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1968-mazda-cosmo-sport 1970 KPGC10 Nissan Skyline 2000GT-R - 2 left: https://www.oemsoko.co.jp/products/1-18-extra-scale-1970-kpgc10-nissan-skyline-2000gt-r
    • When you say basic rebuild, you mean an oem rebuild?
