Still have yet to have a serious convo on here lol I know some are better than others (turbos) but surely someone must of had a good run with the china gear?! A 9sec blue vlt in soom some time ago used a ebay manifold and that was still running fine after 40+ hard passes and 1000s of ks. My old gas turbine project was fine at 25psi and 630deg c. Let the haters hate and the metal fragments fly!
At least you are approaching it with a good attitude!
A guy in adelaide turbo'd and El falcon with an eBay spec turbo. Worked for him. Does that help?
Unfortunately I don't think that you will find much info on them.
Yeah it does thanks ben. Ive got a hell of a lot of mags (friends own a newsagency) seems about mid 2000s everyone from the nissans to ford 250s were into the china gear, some still are given 300+ people have bought the gt35 copy from ebay. Yolo I say so at least I can try 2nd time round and when it blows just get a garrett. I dont mind the extra work
I don't know the dude, just chatted at the track.
He mentioned that they are ok when you find the good ones. Which I imagine us hard to do.
I remember his turbo on the comp cover said "turbocharger" which I thought was funny. Maybe that's a clue to the good ones?
I watch a video the other day, a drift teams was using an cheap turbo so yeah occasionally there maybe a good one amongst the crap ones. The hunt is on, let the haters hate! Also going ebay wg shock horror! Im running a ebay boost controller, intercooler, pipe work, plenum and exhaust. Hell I should just put a massive sticker on "sponsored by ebay" haha
    • The spray cans were in the "Kiln" room whilst I was preping the parts,  so probably around 2 hours to get them warmed up, the kiln room has 3 small ovens running at 100°c, 3 medium sized ovens running 100°c, and the large one I used running at 80°c, the room itself was about 28°c, I also spent a bit of time taping up the parts in the room as well, and by the time I was done I would assume that the parts were around that 28°c As for power, I expect a couple of Killerwasps up high would be achievable with the current mods, I'm still running the MZR 2.0 intake and throttle body, and there is a slight mismatch with the 2.0 intake (smaller) and 2.5 intake ports (larger) on the head, this intake is matched and specifically designed to fix this issue with the ports mismatch, the throttle body is also a couple of mm larger, OEM is 65mm, the Bosch is 68mm In the end it will look "prettier" than the molded plastic thing that is the OEM MZR 2.0 intake As for the LSD, it's the OEM Torsen which works fine for what I use the car for, plus, basically no maintenance apart from the occasional oil change
    • I was at Tunehouse in Marrickville (great team over there really know their VR's) , and I spotted this Very clean R35.
    • Mate , I have the same issue right now with the exhaust noise , if you can tell me what your local guy did , I'll talk to my guys and see if they can do the same. Power is good but it just too loud when put it down.
    • The other trick I've found with wrinkle black is to put the can in hot water for a bit to warm the paint up, and to pre-heat whatever you're painting. It'll be interesting to see if you pick up any power with the intake, following with interest. Got a proper lsd for this?
    • Plazmaman 76mm Pro Series, done. Data to back it up, I posted up somewhere here a few years back
