You can get away with using cheap intercoolers, pipes etc but it all comes down to the fact that when the turbo has the shits and your up for a full rebuild we don't want to have to say we told you so. But it seems from all advice given ur set on a ebay turbo. Go for it let us know what power u make and if it lasts over a week.
  • Like 1
*Sigh* Mr hairdryer sell your skyline to someone who will treat it with the right parts it deserves! Dunno what you are hoping to achieve or prove using a fleabay paperweight but you will prove to us what everyone already knows.. Your car will make faaark all power with massive amounts of lag & drive like a shitbox!
Just cause a drift car uses it doesn't mean shit! They dont care about response when they are limiter bashing them everywhere.. For the sake of maybe $200 MAX a hypergear turbo will eat an Ebay shitbox & be reliable and will have warranty and after sales service. If you dont heed this advice you are a f**kwit!
Wow, man asks legit question sau roaches come out of the sewers to have a crack
I've bought 2 china spec turbos and they are ok for the money.
yes mine are more laggy and make less power then an equivalent name brand turbo but I didnt expect much for the price I paid
another legitimate option for that size and airflow would be a reconditioned holset turbo, not china cheap but around 500delivered from usa. There are quite a few success stories about them on ka24s rb20s 25s honda motors etc
but not on sau
but not on sau
He has been given legit answers.
By your own admission the Ebay special is worse than a decent turbo. Pretty much what every is telling the OP.
There are few success stories for Holset on SAU because they are a worse option that what he is being suggested.
Can lead a horse to water but holding his head under and making him drink is hard work.
but not on sau
So for an inferior result it is a cheap way to achieve it?
The turbo basically makes the power, why skimp on it?
Just over 1000 for a hypergear or second hand garrett. I know what I would do.
i'm pretty sure there isn't a single turbo manufacturer that doesn't make turbo's in china.....get used to it boys...they're all made there or will be....search around on youtube like i did when looking for a turbo and you'll see all the reason the chinese knockoff turbos aren't good...the hypergear turbo's were the best price/performance option of any i had seen and i settled on a ATR43SS2....i couldn't really afford garrett price $2k+ and i was using a GT3076r as a guide for price $2200 here NZD. i bought my turbo and wastegate for a lot less than that. at a minimum you'll have to re-core your china knock off early and you'd have spent the same already as on a hypergear that you wouldn't have to re-core.
Mate there is nothing legit about this question and you and your septic turbos have proven all of my points having owned 2 of these gastro units! You didnt learn after the 1st turbo & i don't know if you have driven a car with a decent turbo before but if you have you would know they aren't worth their weight in piss! I've driven/owned quite a few big $$$ cars and driven some fleabay racers and i can tell you personally that they SUCK!
quote name="#skyginer" post="7402202" timestamp="1412479068"]Wow, man asks legit question sau roaches come out of the sewers to have a crack
but not on sau
Edited by Mick_o
A friend of mine only believes in cheap ebay turbo's. Last week he ordered his 4th one, cost him around $130-150,-. The 3rd turbo lasted him about a week before it blew the seals. If you add all the cost he payed so far he's probably way above a good reliable turbo. The 2nd turbo got him a 14.50 sec at the strip and around 20~ish psi, totally useless scrap of metal. With the stock toyota turbo he went faster lol.
That's my 2 cents.
Not true mick o... all 6 and 4 bangers I take it? A 302 with a pair or ebays hairdryers had a shit load of grunt and would fry em at 80 and do high tens. Guess what?! Ebay turbos!
If you don't understand why it worked that way for that engine, then you really don't deserve to be leading this "conversation".
Imagine how much better it would have been with proper turbo(s). All that engine was doing was using capacity to mask poor turbo specification.
/sheesh. Just f**king sheesh.
  • Like 2
So?
How about I link you to a whole range of 6 - 6.2 litre Holdens with 2x GT3076 or similar turbo additions and let you compare that EB to them? How do you think a 5L + piss poor turbos will compare to something 20% larger with better turbos?
Your argument is faulty.
Edited by GTSBoy
    • Have you checked the foam over the years? No deterioration to the foam from e85 mixing in oil? (assuming you're on E85)
    • Add to this... What blew the fuse too? If a circuit feeding power to the coils was blown, how were the coils even functioning to let the car start?   There is some seriously wrong wiring in that car for certain, and I'm betting there is some melted cables somewhere, but I can't explain the 30v either, unless there is something back feeding on that power line that has a dodgy power system and the electronics are giving it hell.
    • This is typically the case with such threads. What I cannot quite get my head around is where a reading above 12V (or 13.8 or 14.x or whatever the maximum achievable voltage might actually be in that specific car) comes from. 25V or 30V should be completely impossible. There's no way to create it. Hard to answer that question. It will literally depend on whether the current tune relies on the values as set. I'd guess it probably does. ie, the real base pressure being 49 means that the flowrate through the injectors will be higher than if it was 43.5. The Haltech's modelling should be handling that, but because it thinks the pressure is only 43.5, then..... I dunno. It should be thinking that it will be injecting less fuel with each pulse duration than is actually happening. So, something is definitely not-as-it-should-be, but specifically what that is is beyond my abilities to imagine. Someone like Dose who spends more time with Haltechs might have a better thought.
    • Bit of a late reply here as me and my wife have been really busy with new born twins. I finally got these issues fixed and it was something really stupid that caused all of this 🤦‍♂️... After alot of mucking around with trying to figure out what is causing these issues, I back probed one of the R35 coils on the power 12v supply, with the engine running it got 25v! And I thought, hang on..., this isn't normal. Measured my battery with the engine running to check for over charge from the alternator and it wasn't that. So then I dissconnected the R35 PRP coil harness and backprobed the power supply on the engine loom where the ignition coil harness connects, with the key on ignition (engine off) it measured 30v! So then I had to trace where that high voltage was coming from and it lead me to the brown relay "ECM & IGN coil relay" inside the cabin next to the ECU on the passanger wall. This relay feeds power to the ECM and ignition coils. Tried swapping it with another same relay. nah still 30v.. coming from the 2 green/white wires in the brown relay. So then I set my multi meter to the beep continuity mode and probed every fuse on the fuse box inside the cabin to try and find this high voltage power source. Wasn't any of the fuses inside the cabin. Then probed all the fuses in the engine bay and BAM, got my power source that was a 10AMP fuse called "ENG CONT". Pulled the fuse out, and what do you know... it was blown. 🤦‍♂️  So then I quickly replaced it with a new 10AMP fuse, started the car and yeah haha [insert extreme face palm]... The RPM blimping thing went away, car idles smoothly now like what it was before. I swear! I checked all my fuses with my test light twice before I created this forum thread. I think, maybe because one side of that faulty 10A fuse lit up on my test light, I must have thought it was still ok and not blown. But now I know to have both sides light up on the test light when checking fuses... I hate diagnosing electricals.... I'd take mechanical problems over electrical problems any day🤣. Drove the car around my suburb with the engine up to operating temp and it runs fine like before. However, I notice that my fuel pressure is still at 49psi. So I'm thinking this must be normal for my system as I've upgraded the stock fuel pump to a Walbro 255L/h with a constant 12v mod.  But anyway, I'm just glad to have my daily back on the road! Thanks everyone for the replies on this thread, all sorted now! One thing I want to ask you tuner guys, my base fuel pressure on the haltech main settings are set to 43.5psi from default (my tuner must have not checked the fuel pressure maybe when tuning my car?). Do I set it to what it actually is idling on at 49psi? Or just leave it ("if it aint broke, don't fix it/leave it")?
    • The max they would go for me is 50.
