Howdy,
Have done a search and trying to track down some results for the most power pushed through a HKS Hi Power Silent. Some have advised it will be fine, others have said they are too restrictive to push over 600whp.
Going on my E85 slurping, precision 6262 turbo, HKS RB28, R32 GTR
Cheers,
https://www.sau.com.au/forums/topic/449316-hks-hi-power-silent-results/
It'll be fine for your setup.
Its a 90mm exhaust and has no restriction plates in the mufflers.
If you wanted to make it as free flowing as possible then get someone to cut out and replace the small section of pipe that steps down in size near the flanges.
Edited by Chris32R
  • Like 1
I've got an HKS Hi Power Silent on mine, was tuned at ASG last week at 610rwhp, seems fine. It's not obnoxiously loud either which is great.
thats what i was after, i was going to go Tomei Ti, however a few friends have them and they are silly loud for a car i want to enjoy on the street on occasion
exactly the answer i was looking for, 600+ with a HKS Hi Power
its a great exhaust, no drone or rasp in the cabin which makes it top tier for me.
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
    • Sorry for reviving an old post, but I'm having the same hot idle tick issue. Did anyone ever find out what it was?  I have checked/ replaced Injectors Coils checked Lifter clerance (is at zero) Checked Cam lobes Replaced exhaust gasket and studs Would appreciate any advice this is driving me nuts
    • There's a huge reason manufacturers are tuning in dead flat torque curves... Make them reliable (and more drive able)
    • What HVAC actuator is under the steering wheel? Do you mean on the RHS of the centre console, immediately to the left of your shin? If so, then yes, it is probably that one, because that is the mode door actuator, and from what I know, it's still a pain in the arse to replace. I don't know about whole dash out, but you certainly have to rip into the centre console section. I don't know if it's covered in the workshop manual, as I haven't spent much time looking at those parts of it. (and by "the workshop manual, I mean the R32 GTR one, which is the most comprehensive one we have, and it should be similar enough between that and later cars to serve as a guide).
