My M35 runs an aftermarket headunit direct to speakers and I've had this issue since I bought it years ago. Basically if I turn my music up loud it lasts a few minutes (sometimes a solid 15 minutes or so) but eventually all quality is dropped, volume decreases and gets fuzzy/low end gets cut etc.
I always thought it's probably just a faulty head unit but I've since replaced it and I have the exact same issue. Any thoughts on what it could be/how to fix it? I don't even know where to start?
It's just a standard head unit wired in (no amps, subs etc)
Any help would be greatly appreciated!
You are probably overdriving the output transistors and they are shutting down from overheating. If you want to play it that loud you may need an amp.
Hey Scotty, Thanks for the advice. I had thought the same so I went out and bought an amplifier but it did not solve the problem. It seemed to solve the problem for about two days and then right back into it the only difference is that now the volume/power comes in waves; ie it will drop off, then come back a few seconds later, then off again etc. In the past the volume cut until you skipped a track and then it would come back for a few seconds until it dropped off again.
The only change that I can think of that happened on the third day that it started failing again is that it was a cold morning so I used the heater, is that possibly related?
If any one has any advice it would be greatly appreciated!? we aren't even talking excessively loud volume here (just enough to be clearly audible with an open window) and it's an issue that I can never get to the bottom of.
So you definitly do not have Bose speakers? Just the normal Nissan stock ones?
Well I have never checked the labels on the speakers underneath the door cards but unless someone has previously changed the centre console all signs point to no. No sub in boot etc or anything either. Would it change the situation if they were the bose speakers?
Bose system has amps and also low impedance speakers. Driving them directly would give problems on several levels..
Might be worth fitting some quaility front speakers and disconnecting the rears. That should fix the issue, as well as sounding better... Assuming that the new head does not wierdly have caught the same problem as the old one...
Thanks for the tips. Well I swapped the head unit over but used the same wiring jack (it was the same brand so didn't require a rewire). However it doesn't make sense that it would be a short circuit to me because surely then it would be blowing fuses and it wouldn't matter what volume it's at, right? Is there something else in the wiring of the Stagea that could cause this?
in the c34 Prime as I have they use a common ground for the speakers , when I did mine I had to totally rewire the system to create independent speakers , maybe run some wires externally to see if it works before the rewire.
    • Don't do it if your gearbox box has already having syncro issues. The short hifter will put a greater load on them. If you must I remember Nismo did a shorter shifter, with the top part being physically shorter and the part that went into the gearbox was the same as stock. In saying that I've had a C's short shifter (I think) in mine for many years, which was given to me as the previous owner was not sympathetic to the gearbox. Thus forwarned I was careful and had to modify my normal changing style. You have to be super accurate with your clutch and shifts
    • Well, after a week of daily driving and having to crawl out between the wheel and the side intrusion bars. I got myself a quick release setup. I went with an NRG short hub and Quick Release with some cute heart cutouts on the pull tabs. Nice and matchy matchy with the rest of the interior accents I have going on.  The only downside is the total stack height even with the short adapter is longer than the old HKB boss kit. Luckily I had some adjustment left on the column so move the wheel away.
    • stock shifter with new bushes, springs and cup will improve it. Gktech do all the bits. The opinion as the years have gone on is the redline is not great in old gearboxes.
    • Hi all   what short shifter do you use on your skykine r34?   my synchronous does have a problem and i was getting huge delay and grinding sound between 2nd and 3rd, did put shockproof red heavy stuff and it is great now/ no issues   would in your view short shifter screw this up?   people seems to suggest/ use cube short shifter and there is standard and premium. Seen review of premium as much better and less play. Thoughts?
    • Yeah, there's a bit of a density and friability difference between pebbles and any of those other things. Silicone will definitely float in oil and so will be mobile enough to move around. Although, again, if it is upstream of the filter it really shouldn't go any further. I would only ever worry about silicone when it is in places downstream of the filter. Upstream of the pickup is a whole 'nother matter. We've all seen what that does. I have seen the most abominable crap settled out in industrial gearboxes, trunnion lube systems and the like, without any sign that any of it has touched anything in the machine. Just chilling in the bottom, waiting for the inevitable operator error that causes the whole machine to need to be dismantled for repairs.
