My M35 runs an aftermarket headunit direct to speakers and I've had this issue since I bought it years ago. Basically if I turn my music up loud it lasts a few minutes (sometimes a solid 15 minutes or so) but eventually all quality is dropped, volume decreases and gets fuzzy/low end gets cut etc.
I always thought it's probably just a faulty head unit but I've since replaced it and I have the exact same issue. Any thoughts on what it could be/how to fix it? I don't even know where to start?
It's just a standard head unit wired in (no amps, subs etc)
Any help would be greatly appreciated!
You are probably overdriving the output transistors and they are shutting down from overheating. If you want to play it that loud you may need an amp.
Hey Scotty, Thanks for the advice. I had thought the same so I went out and bought an amplifier but it did not solve the problem. It seemed to solve the problem for about two days and then right back into it the only difference is that now the volume/power comes in waves; ie it will drop off, then come back a few seconds later, then off again etc. In the past the volume cut until you skipped a track and then it would come back for a few seconds until it dropped off again.
The only change that I can think of that happened on the third day that it started failing again is that it was a cold morning so I used the heater, is that possibly related?
If any one has any advice it would be greatly appreciated!? we aren't even talking excessively loud volume here (just enough to be clearly audible with an open window) and it's an issue that I can never get to the bottom of.
So you definitly do not have Bose speakers? Just the normal Nissan stock ones?
Well I have never checked the labels on the speakers underneath the door cards but unless someone has previously changed the centre console all signs point to no. No sub in boot etc or anything either. Would it change the situation if they were the bose speakers?
Bose system has amps and also low impedance speakers. Driving them directly would give problems on several levels..
Might be worth fitting some quaility front speakers and disconnecting the rears. That should fix the issue, as well as sounding better... Assuming that the new head does not wierdly have caught the same problem as the old one...
Thanks for the tips. Well I swapped the head unit over but used the same wiring jack (it was the same brand so didn't require a rewire). However it doesn't make sense that it would be a short circuit to me because surely then it would be blowing fuses and it wouldn't matter what volume it's at, right? Is there something else in the wiring of the Stagea that could cause this?
in the c34 Prime as I have they use a common ground for the speakers , when I did mine I had to totally rewire the system to create independent speakers , maybe run some wires externally to see if it works before the rewire.
    • They see me rollin' they hatin'....... Took me most of the day to make the necessary mods to the mounts to make them fit the car.  Fortunately I was able to just use the mounts that came with the rotisserie. The rear ones are really secure, the front I feel i might reinforce a bit more as it doesn't seem like enough attachment to the vehicle. I'm sure it's fine but better to be safe than (extremely...) sorry.  I drilled and tapped thread into additional M12 holes to each car mount where it attaches to the rotisserie as an extra fail-safe. Without them the side to side movement is just restricted by the allen head pinch bolts, nothing actually goes though the beam. Does now! I still need to adjust the rotisserie to get the car centred in terms of centre of gravity. If it's too high or too low relative to the rotational centre line of the car, it will be like a turtle and roll onto its back or as it currently sits, I dont think I'd be able to rotate it as it sits as it needs to lift the whole car up as it rotates. Ain't happening... I'm going to be nervous as hell the first time I go to spin it on its side...
    • Oh yes done this when the window started flopping around.  Turns out the guides that run along the rail chanel had crumbed way. Took off the door card and pulled out the window mech, then the window, which you have to pull out through the top. As said unbolt the guide rail and don't spend 30 minutes getting frustrated trying to find a way to slide it out upwards cause that don't frigging work. Drop it down and out through the door hole. All I did to repair it was slice some 10mm clear plastic tube, vertically, then screw it to the guide rail both sides. This tubing rolls inward on both sides and leaves a gap wide enough to hold the window. To finish all I did was lube the plastic tube with olive oil and Bob's your uncle . . . well if he has the operation he can be your Aunt ! !  10 bucks in plastic tube and another 5 minute job done again . . . . YEH BULLSH#T ! My love for Skylines knows no bounds !
    • So was there a solution to this problem? I’m having this issue now.
    • not expensive, just irreplaceable if you don't go sub 60 at wakie in that thing people will start talking
    • I haven't replaced that, but I have had the doors apart on the r32 a couple of times The door skin will be held on by a combination of clips and bolts, just take it slowly and make sure all the sneaky hidden bolts are out Once the skin is off you should be able to pop that piece off pretty easily, looks like there are only 2 bolts holding it on
