Hi guys, I've had this problem for a while now and its really bugging me, mechanics are telling me its syncros, others say clutch.
I'd like to hear what the experts on SAU have to say about it, before you ask I've searched threads and couldn't find anything that describes what I'm experiencing.
OK so once i start i let it warm up a few min before engaging gear, for the first 3 min of driving its great gears change with ease no problems, as it gets warmer it gets harder and harder to change gears, more so under higher RPM, the gear stick just doesn't want to go into gear, it feels like im hitting a wall! i feel like i can break it trying to do so. lol. I've tried wriggling it into gear, double clutching, nothing works i just have to wait for the RPM to drop to <3k rpm before it decides to go into gear, there's no crunching or grinding. I've tried adjusting the friction point on the pedal.still nothing. What the hell? stationary it goes into every gear. low RPM it goes in to every gear. even down gearing at high rpm wont work.
What are your thoughts?
Much appreciated.
some details about the car:
r33 det series 2
110k
jim berry clutch
original gearbox
shimmed diff.
Wont be clutch, because its fine cold and you've been playing with the friction point. (FWIW If the friction point is too low then the clutch might not be fully disengaging and that will make changing gears difficult).
Have you got newish, synthetic oil of the correct viscosity up to the fill mark? If not, i'd be starting there.
I had an issue like this at the drags last month
Without a burnout no problems at all....after a burnout wouldn't go into 2nd, no grinding or anything just couldn't find home
Don't know what it is so I'm curious to see what ppl say
OP: As with what some of the others have suggested, you need to list what oil you are using. To me it sounds like the oil you are using becomes to thin as it warms up. I would suggest changing oil if there is no problem while the gearbox is cold and then gets worse as it warms up
Sounds like synchro 1st start at changing the oil it's the cheapest option and you can go higher in number if you think the internals are a bit worn out
Say the normal is 75W 90
A higher one is 85W 140
Do a flush so it nice and clean and not metal fragments in their and use a good brand like royal purple.
Tell us what you did to fix ?
Also oil basics
The W stands for winter it's the viscosity when cool so 75 is thinner than 85 but you got no problem there because you have problems with the second number (viscosity when HOT) the 90 this could be old oil and losts it property's or the previous owner was using 140 then when you get service done it's back at 90 also worn internals will need thicker.
Hope it helps you.
Edited by pol1on1
As you've pretty well ruled out the clutch, I'm thinking it's a worn box.
The k's quoted may not be true so try a test and report back.
Drive the car in 2nd and hold the stick hard into gear. Accelerate/back off a few times and feel how much the stick moves against your hand.
Do this in 3rd, difficult trying 1st as the car accelerates too quickly but give it a try.
With a worn box, you get excess end float in the main shaft. You'll feel this through the stick as the shaft tries to move forwards/backwards due to the thrust from the helical gears.
You can reach a stage where the shaft moves too far and even though the synchro has worked, the result is tooth on tooth so you simply can't select the gear.
You may find selecting 2nd is a no-go and 3rd is OK but with a crunch.
(2nd has gone tooth-on-tooth while 3rd has moved too far away for correct synchronisation)
    • I recently got their dbw 74mm throttle body and pedal kit. It is sensational quality especially the wiring harnesses. Unfortunately I can’t answer u about the fitment to stock inlet manifold as I’m going Rahjab Racing forward plenum. Only one thing to be careful of is understand u have to pay gst and import fees if your purchase is over $1,000 in one shipment.
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
