Hi guys, I've had this problem for a while now and its really bugging me, mechanics are telling me its syncros, others say clutch.
I'd like to hear what the experts on SAU have to say about it, before you ask I've searched threads and couldn't find anything that describes what I'm experiencing.
OK so once i start i let it warm up a few min before engaging gear, for the first 3 min of driving its great gears change with ease no problems, as it gets warmer it gets harder and harder to change gears, more so under higher RPM, the gear stick just doesn't want to go into gear, it feels like im hitting a wall! i feel like i can break it trying to do so. lol. I've tried wriggling it into gear, double clutching, nothing works i just have to wait for the RPM to drop to <3k rpm before it decides to go into gear, there's no crunching or grinding. I've tried adjusting the friction point on the pedal.still nothing. What the hell? stationary it goes into every gear. low RPM it goes in to every gear. even down gearing at high rpm wont work.
What are your thoughts?
Much appreciated.
some details about the car:
r33 det series 2
110k
jim berry clutch
original gearbox
shimmed diff.
Wont be clutch, because its fine cold and you've been playing with the friction point. (FWIW If the friction point is too low then the clutch might not be fully disengaging and that will make changing gears difficult).
Have you got newish, synthetic oil of the correct viscosity up to the fill mark? If not, i'd be starting there.
I had an issue like this at the drags last month
Without a burnout no problems at all....after a burnout wouldn't go into 2nd, no grinding or anything just couldn't find home
Don't know what it is so I'm curious to see what ppl say
OP: As with what some of the others have suggested, you need to list what oil you are using. To me it sounds like the oil you are using becomes to thin as it warms up. I would suggest changing oil if there is no problem while the gearbox is cold and then gets worse as it warms up
Sounds like synchro 1st start at changing the oil it's the cheapest option and you can go higher in number if you think the internals are a bit worn out
Say the normal is 75W 90
A higher one is 85W 140
Do a flush so it nice and clean and not metal fragments in their and use a good brand like royal purple.
Tell us what you did to fix ?
Also oil basics
The W stands for winter it's the viscosity when cool so 75 is thinner than 85 but you got no problem there because you have problems with the second number (viscosity when HOT) the 90 this could be old oil and losts it property's or the previous owner was using 140 then when you get service done it's back at 90 also worn internals will need thicker.
Hope it helps you.
Edited by pol1on1
As you've pretty well ruled out the clutch, I'm thinking it's a worn box.
The k's quoted may not be true so try a test and report back.
Drive the car in 2nd and hold the stick hard into gear. Accelerate/back off a few times and feel how much the stick moves against your hand.
Do this in 3rd, difficult trying 1st as the car accelerates too quickly but give it a try.
With a worn box, you get excess end float in the main shaft. You'll feel this through the stick as the shaft tries to move forwards/backwards due to the thrust from the helical gears.
You can reach a stage where the shaft moves too far and even though the synchro has worked, the result is tooth on tooth so you simply can't select the gear.
You may find selecting 2nd is a no-go and 3rd is OK but with a crunch.
(2nd has gone tooth-on-tooth while 3rd has moved too far away for correct synchronisation)
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
