  • 10 months later...
Just a small update, maybe it's usefull for someone in the future.
I bought the -9's and got them fine balanced. I don't have a dyno graph yet because it was just mapped on the street, but I'm very happy with them. Full boost (1,45 bar) is at 3900-4000rpm with Tomei cam gears in stock position until now. Will adjust this on the dyno in the near future and see what it will do for better spool, I'm sure this will bring some extra response and midrange power.
I really like it, that I get the same boost earlier than before. 1 bar was at 3800rpm before, now it's 1 bar at 3500rpm.
Edited by GT-R David
The Garrett balancing is max of 1g up to 30000rpm and max 2g after that.
Mine are balanced to max 0,2g now.
Can upload a chart of the balancing if someone is interessted.
Wasn't that expensive, so thought I maybe won't feel a difference, but won't harm.
This for example is what a normal balancing diagram looks like:
rover-75-1.8-turbocharger-cartridge-chra
The balancing from factory is anywhere below the big line.
I attached a picture of one of mine now
You can see the big line on the left corner. The balancing should be anywhere below the line to meet the manufacturers specification.
I think you won't feel a difference at all. All they say, the Turbos last longer with a better balancing.
This is how the biggest Garrett dealer in Germany discribes the Garrett balancing:
Garrett balanced the core assembly of the GT-R and GT-X turbocharger according to appropriate guidelines in a reasonable and cost-efficient framework. This balancing is usually sufficient. If it's not enough for you and you want a more exact balancing for your turbocharger, we can perform this for you. The costs for this is 130EUR. The work delays the delivery of your turbocharger to a maximum of one working day.
Before and after adjusting the cam gears?
Yes I will.
Yes I will.
should be a big difference, the inlet cam really responds well to adjustment on the RB26
    • So, they simply stick out too far because very wide + very low offset (at the front). At least it's up nice and high so they shouldn't bang into the car too much.
    • Since this is the page where i found myself while searching for wheel fitment, i will add the ones im looking to replace too. Fenders arent rolled, so in big bumps they touch the tire (tires could be narrower). no any adjustable arms, so the camper is what it is (dont know). Wheels: 5ZIGEN Fireball Front: 18x9.5 ET12 - 245/40 Rear: 18x10.5 ET25 - 285/35
    • That’s a beautiful setup Tao, Have u done any development with the new Turbosmart 40mm electronic straight gate, especially in this G30 configuration?
    • Let's hope that's not a copy pump either. There were so many copies of them back in the day.
    • Damn it, I was at work last night, and stayed in a room there during the storm with the car outside, but undercover, I just went downstairs and well....there was a large steel locker that has come from some place last night, it wasn't anywhere I could see yesterday, and yeap, it landed on the fraking car....of course it did..... LOL So, I'll need to take it back for paint and panel, luckily it was only the boot that took the hit, so it could have been worse Serves me right for staying at work and getting on the cans with some of the boys
