Hi all, im new to this forum. Okay so I have recently purchased a vehicle its an r33 GTS-4+T to the best of my knowledge these cars came out rb25de and auto. To put it in a nut shell the 33 is running like a bag boost is cutting out around 4,000RPM-4,500RPM have changed plugs put new gcg high flow turbo but am unsure of how to fix this. Cheers
https://www.sau.com.au/forums/topic/449397-r33-gts4t/
So its running too much boost. As per the million threads about cutting as you have described.
Either the ecu is having a fit due to too much boost or the coil packs are shit.
Or afm or fuel pump or cas or heaps of other things.
So you replaced the turbo to try and fix it? That's a shame..
What ecu? That's likely the problem.
https://www.sau.com.au/forums/topic/449397-r33-gts4t/#findComment-7402493
Try decreasing the boost pressure maybe?
As Ben stated, the ecu is probably trying to protect the motor, go to a tuner and get them to see whats going on.
It can literally be 100 different things. I had a boost cut in my evo, i thought bad fuel pump or batch of fuel, ended up being my intake pipe collapsing on boost. Took me 2 weeks to realize. So yea, literally can be anything.
https://www.sau.com.au/forums/topic/449397-r33-gts4t/#findComment-7402687
    • Does that price include the rack time to straighten the frame and body and replacement of parts and paint, as well as the noise and emmisions testing  The last engineering certificate I had done, albeit about 15 years ago, was around $1000 for a few inspections and the certificate
    • 😂 thanks guys. The diagram i had did not have the breather on it at all. Much appreciated.
    • Geez, engineers fees have definitely gone up. Mine back 2007 cost me all of $300. Mind you, I had to go back to him a few times to get him to write the correct things on the report after he'd inspected it. Things like wrong exhaust size, wrong wheel sizes, etc etc.
    • Can we see a scan of the original quote? The problem with engineers (and by this, I mean, all engineers across all engineering industries) is that there are "engineers" and there are "engineers" (you'll have to imagine the two different vocal emphases on those two versions of the same word. Engineering is a mindset - your farm kid who spent his life rebuilding the tractor will likely make a good engineer. The farm kid who spent his life taking photos of butterflies.. perhaps not. But on top of that mindset, the modern engineer has to learn how to write so that there is absolutely no way of being misunderstood. Proposals/budget estimates/quotations are one place where this is absolutely vital. You have to delineate your scope of supply with extremely hard boundaries, and anywhere where there is any possibility of not being able to have such a hard boundary, you need to write language that will cover you from scope creep, cost overruns, the inevitable interference of the client or their "engineer", etc etc. Now, if your clients are the BHPs and the Rio Tintos of the world, and similar, then you get good at this. If you are an automotive engineer, pitching work to the great unwashed masses, your skills in this area might not be well developed, because you're only dealing with knuckle draggers trying to get a big block legal in a Torana. And when I say "might not"....I'd suggest there's a better than even chance that any such skills might be completely absent. So, we might be able to look at your quote and see what the opportunities are for rebuttal.
