How much is too much? It has 3 bolts that locate it so it really shouldn't move that much. Unless someone has increased the size of the locating bolt holes in the backing plate on yours, any amount it moves wouldn't be enough to worry about.
Edited by iruvyouskyrine
  On 05/10/2014 at 9:57 AM, r32-25t said:
Or the rubber gromets are missing
My money is on this, or they are worn. There is not really that much play in the backing plate when the rubber washers are fitted and in good order.
this is how I get it aligned..
set all cam gears into the exact location, then put belt over it and cable tie it on temporarily as you put the belt over the idler/tensioner & crank. Once everything "looks" ok.. remove cable ties and crank the motor by hand (remove the spark plugs as it's easier).. do it a few times clockwise only.. then check again..
Once she's sweet, nip up the tensioner nut.
There should be rubber grommets and then steel washer inserts which press into the grommets. Last I checked there are four bolts that hold the backing plate to the head, that was on an rb25 head, 20 or 26 could be different.
There isn't enough slop in those bushes and grommets to be a whole tooth out. If it is bad enough that is the case, then you should try and get new grommets and inserts and hopefully that takes out some of the slop.
