2 hours ago, ActionDan said:
He also added:  No problem what so ever Dan I’m glad to help, just for a matter of interest Tomei pon cams are 9.15mm cam lift on both and are 8.7mm valve lift on the intake and 8.77mm on the exhaust, that also means they run very large ramp heights or in other words big valve clearances, that says the lobe is lazy and will have more seat timing that inherits a loss in throttle response, just thought I would put that out there.
Funnily enough, JAGR33 who used to be quite an active member on here put 260 poncams in then ripped them back out for OEM bump sticks for this very reason. "What looked good on a dyno sheet didn't translate into the real world".
  • Like 1
Nice to get the feedback ActionDan, looks like they definitely know their shit and use their experience to design cams that will work.
PS. Half way through writing this post my new Kelford sticks just got placed on my desk at work :banana:
Have still been chatting to Kelford about cams, Josh said he would recommend springs at this boost.
Something else crossed my mind. If I did put these cams in, and he's right about there being 10-12% gain, that would put me around/maybe over 500rwhp. It's a stock bottom end, how much can they take?
Well if I did this, my aim would be to dial in the gears to try and not push it so far to the right, I can deal with peak not increasing much if response can be improved/area under the graph in total increased.
On 27/10/2016 at 10:29 PM, SimonR32 said:
I literally just pulled one set of cams at 250deg 9.15 lift and replaced with 260deg 9.15 lift from the same manufacturer (Tomei). Changed NOTHING else and picked up 300rpm of boost response, so please tell me again how I'm wrong and it has hurt response?
Ok so I have to correct this a little. Turns out that there was 7 deg timing missing so it was helping it coming on a little better than it should. Tune is now done and dusted, Type B are 30rpm laggier (yes 30) and basically picks up 20hp as soon as it's on boost and holds it through top end and holds longer after peak power.
Basically for my application the Type-B are a much better option
Edited by SimonR32
  • Like 2
  • 6 months later...
Finally got some info for people playing along at home. Copy paste from build thread.
Maxxed out fuel pump at 20psi. Last time we ran 24ish.
Need new pump then will take it back to finish it off. What to buy for intank? Currently has brand new direct wire 460lph Walbro.
Detuned for now for safety making same power as before on only 16psi.
Slightly more responsive too, dialled for max response though and now with closed loop boost control. Power is better from the on boost onwards. Will get an overlay of new and old when I'm back there and it's finished but I've seen it myself.
Will be good when finished off, but driving nicely at the moment.
Sounds like a f**king diesel with the valvetrain noise. Tuner said all clearances on the looser side of within standard specification and he likes them there. Can shim tighter if I want. Pros cons?
Dyno graph and vid of loud idle.
Run 3.5bar base fuel pressure, delete the in tank damper/pressure relief valve (if it's there).
Tell your tuner to derive the RPM from the road speed. You set this in the Analyse Screen (F2) and it's under Settings Menu -> Derived RPM vs Speed. Increase the load hold speed to about 100km/h, run the car up to that speed and hit learn (or whatever the button is called).
Hate seeing dyno sheets without RPM and yeah those torque figures are through the roof because there's no RPM.
The valve clearances come on the cam spec sheets. I'm fairly sure Kelford clearances are a good 0.1mm tighter than standard and almost certain you will need much thicker shims
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
