This is just an EOI for co branded jackets and hoodies, we will be needing about 40 paid jackets/hoodies to go ahead with the order.
They will look like this,
With this logo
Prices will be $45 for a hoodie, $65 for a jacket and $35 for a pit shirt.
If you're interested let us know in here and we'll see if we get the numbers.
  1. Cadmoon - Jacket
  2. Cadmoon - Hoodie
  3. Miss-R34 - Hoodie
  4. Triptych - Jacket
  5. Triptych - Hoodie
  6. Triptych - Hoodie
  7. Melly - Hoodie
  8. Melly - Jacket
  9. ZCR - Hoodie
  10. gts032 - Hoodie
  11. gts032 - Hoodie
  12. Shazz - Hoodie
  13. t5iv - Jacket
  14. t5iv - Hoodie
  15. Captain Natro - Hoodie
  16. SABBAi - Hoodie
  17. SABBAi - Pit Shirt
  18. Terry_GT-R34 - Jacket
I am keen for a hoodie or jacket, whatever the majority rules but a preference for a black hoodie with red writing.
We can get a combination of them so hoodie or jacket adds to the numbers.
Yes one black hoodie with red writing :)
(Any chance of prefit for sizing?)
Will be black hoodies with the SAU logo and the black/red jacket with the SAU logo.
Unfortunately the company that makes them are melbourne based so we can't get samples to try first, best I can do for you is a size chart.
Jacket please (in "L")
Thanks Michael
Btw, Mexicans haven't had jackets on offer for quite a while.
About 09 I think we're last NSW jackets from memory... I know Zane got one but I missed out.
  • 8 months later...
    • Sadly I can confirm if you are actually seeking to drift, you will quite easily spin up one wheel. Even if you're going in a straight line. I am not entirely sure of the metrics/terminology here but there's only a certain amount that the helical will actually spin both wheels. I've seen it on video with my own car where two lines of smoke switch over to just one after you really get in to it. Unlike with a clutch diff where you can keep your foot planted until the car regains grip, in my experience with the helical you want to be utilizing traction control allowing LIMITED slip or lifting (partially) when you start to spin up both tyres with a Nissan helical. Which makes them pretty sub optimal for drifting duty. That said... this is probably a helical on numbers alone. Just put the Kazz in
    • Let's just fix the problem by f**king the rest of the gearbox.
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
