Hi all, got a few parts laying around I would like to get rid of.
All items are located in Dubbo NSW. Willing to post at buyers expensive.
I will be attending World Time Attack on the 17th-19th Oct and can also arrange to bring any of the parts with me if a deposit it made.
Stock R34 GTT coupe shocks, stock springs, AND King Springs (only replaced due to fitting coilovers) - $200 (no photo of standard springs)
Stock R34 GTT coupe door trims (missing some parts - as pictured) - $50ono
Stock R34 GTT coupe front brake rotors with all four stock brake lines (unsure of age - only replaced due to upgrade to slotted) - $30
Stock front and rear R34 GTT coupe swaybars (only replaced due to upgrade to larger) - $60ea or $100 for both
The following is being removed from my car this week and will be available after this weekend. Pictures will be uploaded this coming Sunday.
R34 GTT coupe RB25DET Neo Apexi Power FC with hand controller (only remove due to changing ECU) - $950ono
Stock R34 GTT coupe RB25DET Neo Injectors (removed for upgrade) - $100ono
Stock R34 GTT coupe RB25DET Neo air flow meter MAFM (removed only due to upgrade) - $50ono
Stock R34 GTT coupe RB25DET Neo fuel pump - $30
Edited by timmy_89
Will also be heading to pick up my car from Dvs Jez this Saturday, can possibly arrange a meet new Jez's workshop if someone is interested in anything and from that area.
Sorry guys, having internet problems at home, but should have pics of the other stuff up in the next day or two.
Open to offers on all items. Need it gone and need the money to clear defects!
Will be in Sydney this Friday/Weekend.
Stock R34 GTT coupe shocks, stock springs, AND King Springs - Sold pending payment this weekend
Make me an offer on any of the other parts.
Very negotiable on the Power FC if sold this weekend!
Edited by timmy_89
Last day to let me know if you want me to bring any of this with me to WTAC this weekend as I'm leaving tonight.
Price drop on the Power FC + hand controller to $800. Perfect swap in ECU with basic tune already done.
Make an offer on any of the items left, you'll be surprised what I'll take
- door trims
- front brake rotors
- swaybars
- AFM
I will be at Eastern Creek for a couple of hours morning/midday on the 13th December if anyone is interested in something and want to pick it up from there.
Stock AFM now sold.
Make an offer on anything else, I will be at Eastern Creek this coming Saturday afternoon if anyone would like to pick parts up from me there..
    • If it's magnetic what is stopping you from using a magnet on a thin wire from fishing it out?
    • Those 2 solenoids in that assembly I mention, are the PWM solenoids for torque converter lock-up clutch & EPC (line pressure control) ~ when most folks hear of 'solenoid failure', the tendency is to think electrical failure...but fact of the matter is, especially wrt the EPC solenoid (which is moving/running all the time), you can have an electrically 'good' solenoid, that's absolutely broken/worn out mechanically inside...ie; valve plunger return spring rubbing against spring retainer plate, lowering preload pressure.. ...and the solenoid armature extension limit spring wafer with bad wear/broken off petals... ...and if there's ever been any metal flying about, damage to the valve plunger end itself... ...the stuff one never really sees, unless you go the whole 10yards trying to answer the question "why is my line pressure screwy, but TCU isn't flagging any EPC solenoid fault?"...and carefully dissect the solenoid. Worst (and most probable) scenario is when the plate spring petals break off, they get held by the magnetic flux, get mashed up by the armature into little bits, which end up in the space between the armature & shading core bore, and things get stuck or randomly jam up, and your line pressure goes flat and doesn't change...and the TCU never sees it, as it doesn't actively monitor LP... ..then it gets into insidious land, if you end up with lower than expected line pressure...lets say high clutch..and the lower pressure causes it to slip ~ when I say 'slip', think say 2000rpm on the drive plates, and 1800rpm on the driven plates, because the slip is making them under-rotate by 200rpm ; you get all the usual nasties like heat and band/clutch wear, but even if it's only 20rpm slip the same thing happens...and... you'll hardly ever pick this up driving the thing with the torque converter active as it effectively masks these sorts of slippages that are line pressure related ...(the newer TCUs can detect clutch slip rate)...just  FYI as it were...
    • There's nothing that some paddle pop sticks and extra cable ties can't fix.
    • Hey guys, so Golebys has good prices on Bosch injectors, and also sell an adaptor to go from 1/2 length injector to standard with the Nissan 10.5mm top seal.  Does anyone know if that adaptor is to suit the 14mm or 11mm injector tops?  And re. The bottom seal, to suit my standard RB20 intake, would I be right in saying I can just slip the 14mm square section O ring over the bottom of the new injector and done? Thanks in advance guy, Cheers, Rowdy
    • F my life. I was changing the oil on my R32 GTR today as usual and ran into a bit of a snag. I drained the oil out and was getting ready to finish the job by tightening the drain plug, however The stupid magnetic oil drain plug snapped in half, right at the magnet part. After about an hour of trying to remove it, I used a drill bit, which unfortunately pushed the magnet all the way into the pan, and just leaving the hollow threaded part of the bolt remaining. I was able to remove the hollow portion of the bolt from the oil pan with some pliers but the magnet is still in there.  So, the question is, should I drop the oil pan to get the magnet piece out, or is it okay to leave it in there? I really dont want to drop the pan, i'm about to go nuts.  PSA: Do NOT buy a BLOX magnetic drain plug. This is the one i had.    https://bloxracing.com/products/magnetic-oil-drain-plug-m12x1-25mm?variant=37131252859052&country=US&currency=USD&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&gad_source=1&gclid=CjwKCAjw47i_BhBTEiwAaJfPpgti1D2JwO7TDuMpXuqeQPCuIQSAfwxpWQH5rF9MD7sm5SCZDWLR_RoC_YoQAvD_BwE
