Cheap mig haha. I have more money in welders than every cent in old mates stagea from site work actually.. Let alone the welders I have access to in the workshop. What qualifications do you have exactly to talk down a cert 4? Haha yeah guys so impossible to knock up some engine mounts hey.
Thank you!! It doesn't bother me to much man, all car forums are the same, everyone thinks being a wanker makes them look funny and tough. In reality they just look stupid, they don't have enough knowledge to answer a few simple questions so they start throwing around insults. some people just don't get it. Thank you for being the only one that actually read and understood what I said.
friggin hell there is some retards on here. The dude quite clearly says he is aware of it not being the best option, and explains why he is doing it, to get a cheap car going. But no, everyone has to run him down and rubbish his ideas, cause it's not what 'they' would do. F&*ktards.
If you have any info to help him, post it. Otherwise STFU and quit being keyboard warriors.
my last comment was supposed to be a quote to your comment whoops
I'm sure you do
Gogo name what you have
Heaps of money in mig welders but no money for a shell or decent engine?
Cool.
Anyway you know your answer. The tails haft will need changing. So either shorten it or lengthen it when you do the conversion. You can do it. You told us.
Cool.
do you think I would rather spend money welders? I need to work I don't need a skyline engine, it won't make me any money will it. Actually if you can read I asked if any other tail shafts would fit instead of me modifying. Don't just say I said shit to support your argument. Will post a picture of all my welded when I get to my computer :)
Also it's pretty obvious calling someon and their plans retarded is a bit more than rude, and you know you were doing it. I didn't tell you guys anything and I wasn't rude to anyone who wasn't a tosser to me first.
Edited by mattymatty4
Well to put it into perspective
I paid 4k recently for a registered tidy R33 Gts-t
Which is why some of us are saying its a waste of time
Wow that's cool, and totally irrelevant to my thread. I didn't ask for the price of registered 33s I asked for tail shaft help, I'm really happy for you and your purchase but I'd rather do it my way. I enjoy working on my cars and would have fun building it. Is it that hard for you to understand what I'm saying?
  • Like 1
In what?
In anything really, mostly your fabrication qualifications. What right do you have to talk down a cert 4 in engineering fabrication? You wanna tell me I can't make some engine mounts? You seem like someone that works in an office to me. "Oh I went to tafe 2 days a week" hahah go on you pass a welding test and tell me it's easy
Hmmm. OK, so I'm not out. I'll come back in just for a laugh.
As to qualifications......Let me see. The last thing I designed for a customer weighs about 6 tons, was made from a mixture of mild steel, 304L, inconel, various bits of tool steel and all sorts of other bits and bobs. I had my draughtsmen (yes, plural) work up the 30 or so drawings for it. It took 2 weeks to draw, 6 weeks before that for design calculations and CFD modelling. Cost the customer about $200k. Oh, and they bought two of them. And each one is carried on a trolley that weighs about 10 tons, runs on overhead rails, has hydraulic adjustments for total height and vertical and horizontal angles, plus 2HP electric motors to drive along the rails. Operating environment temperature for the front end is about 1500°C. Well, the flame is probably more like 2000°C. Oh, and I did the site survey and the installation work in South Africa, which was nice. I got to go on safari in the Pilansberg afterwards. While I was there I visited another customer's site and will design something similar for them very shortly. I do this sort of shit several times a year, in between consulting for people to work out why they blew something up (hopefully without killing someone), or how they can stop something undesirable happening in their process, or just doing esoteric calculations on heat transfer, energy balances or the like.
So, I'm not going to tell you my qualifications. It wouldn't be fair to you.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
