As per the topic i am considering buying this used hks gt-rs turbo for my s15. I have bought a few used turbos before but i just thought i would ask here for some more opinions, I am mostly concerned about the amount of corroision and the colour of the exhaust wheel and wastegate flap. Does it look like its had a hard life? I have the money to buy a new Gt2871R but this used turbo is less than half the price and i wouldnt mind saving the money if it looks ok.
Thanks guys
https://www.sau.com.au/forums/topic/449502-does-this-used-turbo-look-ok-to-buy/
Apparently the turbo has no shaft play and no marks on any of the compressor/exhaust wheel fins or inside the housings they run in.
I'm mostly concerned about the colour of the exhaust wheel and really and havent been able to find much info on it. The turbos ive bought in the past have had black sooty exhaust wheels. the only other turbo i have at home in one i changed on a saab because it had stopped spinning and the exhaust wheel on it looks a similar colour to this gt-rs
Im wondering if it was running to lean, or if it was on e85 or another type of fuel, there is very limited info from the seller as he bought a rebuilt sr20 and it came on it.
I would personally buy one new if you can't see it in person, heck I'll even throw in the Hypergear turbo idea... probably matched performance and new for a little more than that 2nd hand turbo... not to mention awesome support & warranty
buying a 2nd hand turbo is always a bit sketchy as it is super easy to clean any oil out of the comp housing to mask seal issues.
Buying one 2nd hand without seeing it in person is even more sketchy.
I'd suggest the hypergear line. Message Tao and tell him what power range you're looking for and he will tell you which turbo will do it with the best response. Easy; and as Johnny said it will have a warranty.
I'd be willing to bet it's not that much more expensive either
I believe the guy that there is no shaft play and have had luck buying used turbos before that are still running fine 10 years later. Anyway what is the hypergear equivalent to a 2871r 52t .64 or gt-rs. I know they are the same lets not do the Hks vs garrett debate on this turbo.
I don't see the point of going one size up with a 2860rs .64 aka disco potato .64. I don't want to change the cams from stock and want 230-250rwkw. I'm thinking upto 20 psi boost no more on 98 octane.
Stock turbo is fun and handy around town but I'm just bored with it really
mate be VERY careful about buying any second hand
I just went through the headache of buying "5000km old" GT SS turbos, looked fkn immacualte, mechanic inspected said fractional shaft play on one, oither was g2g.. once installed it was fked out and wouldnt boost properly when getting tuned.
Cost me an extra $5k for new turbos, stud kit, labour of the changover, tune and then the extra 2 and half hours of tuning already conducted on the old set (what should have been 6k for my job turned into 11) because a second hand turbo that seemd fine was bad
Not saying this will happen to you, but you need to ask yourself is the 1k ish saving worth the thousands of dollars of risk and the uncertainty of what your getting. Plus the GT2871 (or equivelant) will be a more powerful unit, so it depends if you want more room to move.
my 2c
    • Boot is going to be replaced eventually. I just wire brushed what I could and rust converted. Then painted in rust kill primer. the spoiler also got repainted and plugs replaced on the ends. The under side of the bonnet is going to be black also, currently white. But red on the top side, same colour code as the silo to begin.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
