Hey guys,
Im stumped on a fuel issue in my R34 GTT,
It's hitting 100% duty cyle at 11.9 AFR up top at around the 500rwhp mark. Any help would be appreciated!
I've attached some screenshots of my map if it helps? Fuel pump has bigger wiring to it with a relay and direct battery connection.
Mod list below.
Standard RB25 NEO
Steam pipe high mount manifold
Garrett GTX3582R V-band rear housing
Turbosmart ProGate 50mm
Bosch 1000cc injectors
Proflow fuel rail
Tomei fuel pressure regulator
Plazmaman plenum
Haltech Platinum Pro ER34 Plug-in
Haltech 4 bar map sensor
Haltech boost control solenoid
Haltech flex fuel sensor
Splitfire coil packs
Custom stainless dump and front pipe
100 cell Venom cat converter
HKS HighPower 4" cat back exhaust
600x300x100mm FMIC
Tial 50mm BOV
Walbro 460lph E85 fuel pump
Edited by TheGeniusMoose
how's your fuel pressure though?
I'm hitting 97% with 875cc injectors on E85 with about 1.6bar boost - however running 3bar base pressure. Newer injectors don't mind more fuel pressure, so once I need more "injector" I will bump the base pressure.
interesting. the Walbro pump should be able to handle more than that for sure. As well as the injectors.
How much boost was used before the injectors maxed out?
perhaps the fuel pump isn't genuine?
Do you have a direct feed for the pump?
I believe those ones can draw close to 20A at high boost. That's more than I'd be comfortable putting through the factory fuel lid connections.
Maybe drill a hole in the lid and poke some high current wires through then seal it up
Pump has direct battery feed with a relay, geniune pump. The lid has nice thick wires and does not get hot.
24psi boost.
next question is, did the tuner tune to AFR or to Lambda? correct Lambda should be around the 0.81 mark... if your tuner tunes using afr his calculations could be way off in which case it's probably mega rich hence why its maxed
I'm honestly not sure.
The dyno chart shows that its at 11.9 at peak power. I didnt take a picture however.
I'm also using standard fuel pump cradle, standard lines under the bottom of the car.
Any time anyone says an AFR number when talking about E85, and the AFR sounds like a petrol AFR, then just pretend the fuel is petrol. It's that simple. No-one would tune to a real AFR of 11.9 on E85.
  • Like 1
What fuel filter are you using?
I'm not joking. I upgraded the injectors in your situation and had a limitation at that exact point.
Mind you, this is 372rwkw. It's getting 'up there' for 1000s.
If your AFR's start OK then start to leeeean out to about 12-13 as you really get into it.... seriously try something else instead of a Ryco filter. Try a dyno run without one.
Will try with no filter just too see what happens. It is running a cheap ryco one at the moment...
Who should I be taking it to so I can get this shit sorted? I'm in Brisbane.
I have had a few 34's doing the same thing lately on ethanol, large injectors suddenly maxing as the fuel flow drops off. As Greg said, we removed his filter while it was on the dyno and the entire fuel map went rich.
His Ryco had only recently been changed too. We replaced it with a stainless mesh filter.
Exactly, that is how we found the flow was dropping off. You have no idea what is happening without a gauge on the feed line, and you need to be on a dyno if the gauge is in the engine bay.
Speaking of which, it seems some factory regs can be too small for the 460L pumps, they don't bypass enough. The S15 I worked on recently was tuned at 60psi at idle, no wonder the car wouldn't idle well with twice the fuel pressure it should have had. It is definitely an important test that should be checked after any major fuel system mods.
Fuel gauge on the feed line? Is a gauge on the reg not able to tell you correct fuel pressure?
Well I just bought a speedflow filter with barb fitting to replace current ryco one and a new bulkhead fitting for the cradle as a few people have said the stock fitting is very small. I'll have a fun weekend ahead of me!
my walbro e85 pump is making 450rwkw at 24psi on e85 no problems so don't think its the pump
I think your injectors are at the limit, my old 1200cc injectors were at 100% duty at 409rwkw with 55psi base pressure
    • Hows your intake piping? Are you still running stock? Having in the stock AFM position would mean, if the BOV was shut/venting out, it'd create the almost stalling kind of effect right // "the rich pulse behaviour" due to MAF thinking air is flowing ? But this would be better than having the bov in the stock position + MAF on/just before cross over piping right?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
