what he said ^^^ :)
mine were gonna be getting around the 100% around the 360kw mark with an E85 walbro pump so i upgraded to 2000cc inj. food for thought
Did you check and monitor fuel pressure on the dyno?
So I've just taken this ryco filter out..
Cannot blow through it. It's clogged so bad it's not funny. As in, air goes in and doesn't come out the other side clogged .
from my experience hearing from people running E85 i dont think you get much change from 1000cc inj, after about 350kw :)
**** running E85.
is the guy that built your car running E85?
correct me if im wrong but running more fuel pressure you can use less duty cycle??
Replaced filter, 80% duty in 3rd at 7500 rpm. Not sure how that compares to 4th gear on dyno however.
This was my exact experience.
I have heard other people run into walls at ~330-370kw with mysterious fuel problems on R34's when everything else seems ok, replace the filter. At least on E85.
I upgraded to 1400's thinking my 1000's had maxxed out but found out that wasn't the case. 1000's on e85 seem to really get hairy at 400, though some people reckon they've done 450+ on them? Can never really have too much injector headroom nowadays anyway. Good enough excuse to upgrade :P
Exactly, that is how we found the flow was dropping off. You have no idea what is happening without a gauge on the feed line, and you need to be on a dyno if the gauge is in the engine bay.
Speaking of which, it seems some factory regs can be too small for the 460L pumps, they don't bypass enough. The S15 I worked on recently was tuned at 60psi at idle, no wonder the car wouldn't idle well with twice the fuel pressure it should have had. It is definitely an important test that should be checked after any major fuel system mods.
are the nismo considered factory reg ?
No, they seem to work fine. I only realised the SR regs were too small after having idle issues on petrol after installing a 460L intank. Checked the pressure and found it way too high. Perhaps the RB's will be fine as there are 2 more injectors bleeding fuel pressure off...
    • They're supposed to not be compatible.
    • Evening fam, Pretty much what the title asks, I have looked all over and can’t find a proper answer expect one post from almost a decade ago which is vague. ive seen photos and they look pretty much identical, would an r33 GTR N1 reo work on an r32? reason I ask is they are cheaper to buy… $700 compared to 1k+ for an r32 n1 reo
    • Couldn't help myself, had to start putting it together.... It really is a solid bit of kit.  Probably stronger than i would have made it myself to be fair! 🤣🤣 Sweating like a pig after that.  Bloody hot and muggy day today, time for a swim now!
    • Yeah was thinking that. I've had the car go lower idle possibly around 650rpm every once in a long time after pouring fuel and would sound quite rough like a misfire, almost like it's shit fuel or something but who knows.
    • @Wazmond you are correct, my bad, was not my intent    https://www.facebook.com/share/15ZMn5oXtc/ Updated Event (so its not private and can be shared easier)  Attempting to coordinate a big push of Stagea's to this years GTR Festival. Great event last year and hoping for the same this year.    I've emailed them to ask to set a location aside for the Stageas for the show and shine - they are happy to do so if we can get them numbers, I'm happy to keep track of that. Entering as Nismo category.    I'll be road tripping up from Melbourne, would be cool to convey if people are interested, maybe there is SAU convoys from each capital? If you have ideas about that let me know.    https://gtrfestival.com.au
