Hey guys
Got a brand new set of Aftermarket headlights for Nissan Skyline V35 350GT Coupe with Halo rings and DRL in Black housing.
Bought them from japan and not Ebay so they are 100% legal for RHD vehicles (boxes have instructions to install in japanese)
Asking for $690 ono
Pics for illustration only, i have not even opened the actual boxes.
Can be posted on buyers expense
If anyone around Sydney interested, i will be driving down in a weeks time for WTAC
thanks
Edited by AsM
  • 3 weeks later...
    • It is an absolute lottery. They can and have died at stock boost with low usage at all. The turbos are now anywhere up to 36 years old!
    • Huh, wonder why it blew then. I never really beat on the car THAT hard lol I dailyed it and the turbo blew after 6 months
