So I love working on cars and I have a fair knowledge of how they work. But whenever it comes to wiring I get lost. How can I learn more about auto electrics. I just bought a Cressida for 300 bucks . ( bargain ) and would love to do I 1jz swap one day. But I know how expensive auto sparky's are. So how can I gain some knowledge.
https://www.sau.com.au/forums/topic/449534-how-can-i-learn-more-about-wiring/
Online tutorials is the easiest way to get the basics.
Or as silly as this may sound. Go and ask to do work experiance at an electrical workshop for a week. They may give you shit jobs but they will explain what you want to know during your time there.
We would have 6-12 work experiance people a year through our workshop and they quite often come in after wards and get supplies and information/ help with there projects.
Auto electricians are expensive as they would have firstly done a trade course and then studied the basics used in modern cars trucks, campers you name it.
They'll have a working knowledge of engine management, charging systems, aircon and so on.
You can't expect to understand all this without proper training and Youtube, Google etc will only bury you with useless info.
For your situation, (a re-power) I suggest you study the wiring diagrams of both vehicles so there's no surprises when you tackle the job.
Ask questions on their forums and soon you'll have that required knowledge.
I will defiantly try and watch some youtube tutorials, but I don't really want to spent the money for tafe as I just want to learn the basics so I know what I'm looking at. Where can I find a workshop manual for a r32 gtst? My car doesn't have one. And a 89 Cressida.
    • Yes...but look at the numbers. There is a tiny tiny fraction of the number of Joules available, compared to what is used/needed. Just because things are "possible" doesn't make them meaningful.
    • Thanks for taking the time to post that ! If anything changes or happens please do update us.
    • Somehow Vertimass/Oak Ridge National Labs has figured out a catalyst that can convert ethanol into C9-C10 hydrocarbons in basically a single step without ending up with a bunch of ethylene or similar waste products: https://patents.google.com/patent/WO2023224867A1/en I still don't think anything like this will keep us from needing to transition to EVs regardless along with all kinds of other electrification, but things like this will go a long way towards alleviating the problem of how to electrify things like planes. Renewable diesel is seemingly an easier problem as well, Chevron is already running refineries for the stuff and the primary feedstock is tallow and other waste fats from agriculture.
    • Ok so I have sorted everything with my uniclutch and  i can offer up a bit of feedback and some things that might help others.    I found problems with factory damper line. Weird shit and had trouble with peddle adjustment    I used this https://au.gktech.com/products/r33-gts-t-skyline-braided-clutch-line?_pos=2&_sid=22b01b9b9&_ss=r Also when adjusting peddle leave a bit of play. You can get into a over stroke condition easy.. Make sure you can push the slave forward after adjusting to confirm fluid can return to master then you will need to pump it up heaps…..not sure why but that’s how it is.    last thing the splined adapter is machined perfectly. If your input shaft is old like mine was I would put a bit of valve grinding paste on it and stroke it like a 15 year old. Just to give it a tad more clearance and to better match it to the spline.    reason is on a near flat shift I have had situation where the peddle returns a millisecond after you lift from the clutch. No slip or anything but I reckon this is due to tolerance on the spline being way tighter than stock clutch and binding for a sec. I think this will go away but also my spline was old. Box is old so I guess I should have checked better. It’s a super neat fit.    it feels light as and holds awesome without any noise
    • My Fuga Hybrid is JDM, 2014 model but very similar to the V37 from the looks of things..same platform just physically larger and very comfortab;e
