*******************PLEASE TEXT OR PM FOR PICS ON THE NUMBER BELOW********************
N1 oil pump used for 1000kms before upgrade $250
N1 sideskirts and rear pods for r32 gtr white $650
N1 brand new oil pump gears $50
APEXI power fc and controller $600
APEXI power fc PRO $600
APEXI power fc d jetro 2 months old $1000
ACL race series engine bearings standard size big ends and mains $200
NISMO 555cc injectors $300
NISMO castor arms for r32 gtr $100
NISMO coilovers for r33 gtr height adjustable $500
ARIAS forged pistons 86mm few little marks nothing major $270
HKS intake and mushroom filter kit $150
HKS intercooler hard piping kit missing top piece that goes to plenum $200
HKS triple plate clutch great condition $1000
HKS T3G turbos for gtr need rebuild old school hks 2530s bush bearing turbos $400
VEILSIDE cat back 3'' exhaust $200
SPLITFIRE coilpacks r32 r33 gtr $350
TRUST type R bov $300
TRUST GREX oil cooler and relocator 1 month old removed from r34 gtr $600
JUN drop in cams 264deg 9.15mm lift good condition $500
BOSCH Z32 arm month old $150
ADJUSTABLE cam gears $50
BILLET fuel rail $90
GENUINE NISSAN headgasket $50
RB26 head complete with covers $1000
RB26 complete plenum intake $300
RB26 fuel rail $20
RB26 polished twin turbo pipe $90
RB26 balancer $50
RB26 alternator $70
RB26 oil pump $50
RB26 water pump pulley $30
RB26 front timing belt cover $70
RB26 standard cams $80
RB26 standard turbos need rebuild $100
R33 GTR rear strut brace $70
R33 GTR front strut brace $70
R33 GTR rear seat $150
R32 GTR drivers side gaurd $190
R32 GTR front seats no rips $500
R32 GTR rear seat $100
R32 GTR radio surround mint like new $80
R32 GTR complete doors $100 each
GOLD COAST but can post
0487924497
https://www.sau.com.au/forums/topic/449538-gtr-aftermarket-standard-parts/
  • 2 months later...
    • I know this one’s the BB one. My tuner did make mention about the actuator. I am curious about the VCT as well
    • Might also needs a stronger actuator with the right preloading. With older 2019 built bush G3 units, BB upgrade or 21U housing down size makes a pretty decent gain in response as well.
    • Hey lads  so im finally putting together my rb30 forged bottom end and ran into an issue. I measured my main bearing clearance with arp main studs torqued to 60 ft-lbs using ACL H series STD size bearings and standard, un-ground crank shaft journals and got an oil clearance reading of about 1.3 thou measuring straight up and down and about 2.8 thou measuring at a 45 degree angle (just above and below the parting line). My machine shop said they measured the main tunnel and it was all within spec (they didnt say the actual measurement) and to go with a standard size bearing, which i have done and the clearance is too tight, I'm guessing because of the extra clamping force from the arp studs distorting the main tunnel. I was wanting to run about 2.5 thou main bearing clearance.  My questions are: 1. could i just use the HX extra 1 thou clearance ACL bearings? that would fix my straight up and down clearance making it about 2.3 thou, but then would the side to side clearance be too big at around 3.8 thou? 2. what actually is the recommended main bearing clearance for measuring near the parting line / side to side. i know its supposed to be bigger as the bearing has some eccentricity built into it but how much more clearance should there be compared to the straight up and down measurement? at the moment there is about 1.5thou difference, is that acceptable or should it be less? 3. If i took the engine block + girdle back to the machine shop and got them to line bore the main tunnel (like i told them to do the first time, but they said it didnt need it) what bearing size would i buy? the STD size bearing shells already slide in fairly easily with no real resistance, some even falling out if i tip the girdle up-side-down. If im taking material out of the main tunnel would i need a bearing with extra material on the back side to make up for it? this is probably confusing af to read so if something doesn't make sense let me know and ill try explaining in a different way. My machine shop doesn't come back from christmas break until mid January, hence why i'm asking these questions here. TIA for any help or info
    • I bought the model back in Japan in Feb. I realised I could never build it, looked around for people who could build it, turns out there's some very skilled people out there that will make copies of 1:1 cars or near enough. I'm not really a photo guy... but people were dragging me in a group chat for the choice of bumper as someone else saw the car before it was finished as they are also a customer of that shop. I took the photo in the above post because I was pretty confident that the lip would work wonders for it. Here's some more in-progress and almost-done pics. It gives a good enough idea as to what the rear looks like!   I have also booked in a track day at the end of January. Lets all hope that is nothing but pure fun and games. If it's not pure fun and games, well, I've already got half an engine spare in the cupboard
    • Well, do ya, punk? Seriously though, let's fu<king go! The colour and kit looks amazing on the car. Do you have any shots from the rear? I don't quite follow how the model came around. You bought the white kit and he modified it to match your car? Looks nuts either way!
