Running a single 044 now fed from a surge tank which will run out of flow on E85 and I would rather not change my surge tank to a twin outlet if I don't have to.
Can anyone give me any ideas on big single high flow external pumps are up to the task?
Only one that seems to fit my requirements so far is an A1000 from Aeromotive... Would this be suitable?
Aiming for 500rwhp from a 4cyl.
Thanks, G
https://www.sau.com.au/forums/topic/449548-single-high-flow-fuel-pumps-for-e85/
The Walbro is intank, not sure how it would go as a external :/
I have a Weldon 2025 and it will pump anything and lots of it but is noisy as all hell
I am looking into the Fuelab Prodigy pumps as they are suppose to be a lot quiter then the Weldon and have some good flow rates
I've heard the A1000 is suppose to be fairly noisy aswell
Thanks for the feedback.. Will look into it now! I haven't seen a Walbro pump to suit the flow I need as an external pump. Only seem to find in tanks.
Doesn't really matter what pump, just as long as it's reliable enough for the job.
@Joshbigt62r - Mainly just my street car and weekend fun. But I would rather future proof it!
Edited by Gareth87
You could easily run a Walbro 460 in the surge tank with a few small mods.
If you want a large external, make sure you can control the speed so as not to overheat the fuel. Something ecu controlled like the Fuelab with PWM input is perfect, other brands will require a separate controller.
Interesting about running the Walbro inside a surge tank. would have to seal up the tank pretty well though.
With the big external pumps, why is keeping the fuel cool so important? Does E85 have a tendency to heat up and cause issues?
I suspect hot fuel may also cause the black gunk I sometimes see around injector tips on e85 cars. Molasses is a by-product of the sugar refining process, and that's just what it looks like.
im no expert but i guess its the same question as whats so bad about having my oil, coolant, and air really hot.. is it going to make much difference.... well of course you want to keep everything as cool as possible.. not too cool but you get what i mean.
How hard is the Walbro E85 pump to mount in an R33? I have the Tomei/Nismo pump at the moment, and its great, but is a few years old now and thinking of upgrading it. Just not too sure if its worth the trouble of fitting the Walbro pump or not
Hoping to have E85 at the pump here soon. I'm pretty sure the Nismo pumps handle it no worries, but the Walbro one is designed to run 85 and flows more so seems like a smart choice
definatly the smarted choise, and is pretty cheap from memory, like $200, it fits into my r34 gtr but from memory the tuner told me all that needed modifying was the connection onto the pump. if your looking at running E85, you would want a pump that is designed for it and with 460LPH pump you will have no dramas in the future when you decide to push more power aswell. i would even upgrade to 2000cc inj aswell so there will be no need to worry in the future
I just got 1000cc top feeds I have to put in. They will be plenty for the moment
Might look into the walbro pumps a bit more. I just love how easy my nismo pump was to install and how nice it runs. But it wont last forever and I'd rather replace it as a preventative measure rather than reactive when it fails
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
