Venting the can to atmosphere is illegal and unnecessarily dumps really nasty crap into the air. You should plumb the vent into the factory breather fitting, that is, insert the catch can in the factory system, in the line that runs from the cam covers to the connection in the inlet.
If you do that, you'll totally get more hot babes because you will be far more awesome.
https://www.sau.com.au/forums/topic/449559-catch-can-smoke/#findComment-7406054
Thankyou for your comment. Driving it like a granny as I want to preserve its life for as long as possible. And my question makes reference to, what could be the possible cause of the lowish compression, rings or valves?
Pull the plugs. Squirt a little oil into each cylinder. Retest. If the compression comes up it its more likely to be rings. If not then valves. But having said that with the uniformity that you have its more likely rings.
https://www.sau.com.au/forums/topic/449559-catch-can-smoke/#findComment-7406114
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
