As stated in the title brand new dry sump kit for RB26DETT will fit R32, 33 or 34 GTR requires modified front sway bar for clearance of the pump (Whiteline sway bar supplied with R32 GTR kit) The kit has been extensively tested on several 450 + KW GTR's and is the kit the Employment Medicine R32GTR that will be running at world time attack is fitted with.
The kit consists of.
1 x Peterson (R4 Model) 5 stage oil pump.
1 x billet oil pump mounting bracket.
1 x Peterson 3 gallon oil tank.
1 x oil tank mount.
1 x Breather tank (for the main oil tank)
1 x billet drive spindle to suite either ATI 1000HP/ATI600HP balancer.
1 x billet oil block (replaces factory heat exchanger oil filter mount).
1 x remote oil filter mount.
1 x Custom internally baffled RB26 sump with 3 oil pick ups. (front diff not included).
All oil pump drive pullys and belt.
All bolts required.
All the billet parts in the kit are machined from 7075 T6 aircraft grade aluminium and anodised black.
The only thing required to fit the kit are braided hose and fittings.
Please Note; The pump shown in the pics attached is the older style G Rotor Peterson 5stage pump the kit is now supplied with the newer R4 style pump.
THE PRICE FOR THE KIT IS $7500.00 INTERESTED PARTIES PLEASE PM OR CALL ME ON MOB PH 0417305401. DAZ.
https://www.sau.com.au/forums/topic/449561-gtr-dry-sump-kit/
Not that I can afford it - for me this is the type of gear dreams are made of... but just so i understand it better, im assuming the tank would get mounted in the boot and the oil line gets mounted under the car or what?
Gavin
Yeah Gavin the pump in my set up is mounted in the boot with the lines running under the car as my car still has rego. A lot of guys with track only "Non Rego Cars" will often mount the tank on the passenger floor.
Hi,
Can you also provide a pump and pulleys for a RB30?
Hi racegtst the pump and pulleys will be the same but I would need to machine a separate bracket for the pump mount if you are definitely interested send me a pm and we can discuss further.
that isn't an r4 pump. nice kit.
Please read the entire post mate i do mention at the bottom of the post that the pump pictured is the older style G Rotor pump but the kit will be supplied with an R4 Pump.
  • Like 2
  • 3 weeks later...
And how much use has the pump had??
Everything in the kit is brand new mate this is a brand new complete kit.
As this is the last full kit I have for sale as I have two more going onto some project cars I'm willing to take $6500.00 absolute bottom dollar to move it.
  • 3 months later...
    • So the clockspring is responsible for the indicators cancelling on their own? I thought that was the function of that green thing in the center (any idea what it's called?)
    • Can you log IAT? Whilst WTA coolers have their place, doing any sort of sustained run is not one of them There are fixes that slow down the heat soak, like ice boxes, which don't last that long, and interchillers, which are fairly expensive, up grades to the WTA cooling radiator, which may require a bigger pump, and upgrades to the reservoir size,  and upgrades to the cooling fans, but, it all still heat soaks, and takes ages to come down in hot weather  For a turbo, that isn't locked into WTA like my PD blower is, can you not possibly swap to a nice air to air intercooler????, it would be better for sustained runs then, and have alot less things that could go wrong in my opinion
    • So, the other thing I've sorted is a baseline dyno run up at Unigroup's new location. The auto trans was a little unco-operative by both shifting down when the throttle was floored on the dyno (so Mark had to ramp it up more slowly than in a manual) and also by shifting up at 6,000 even in sports mode instead of the indicated redline of 7,000 Still, on a hot day it made 240rwkw at 16psi which seems about right for 300kw (400hp) through an auto at the wheels.  The shape of the curve is not quite right because it was not full throttle to about 4,500 to stop it kicking down, but until I can get a tune on the auto trans control this was the best we could do.....full boost will be well below 5,000 once that is sorted, I'll get some data logs when I can to confirm For comparison, the R32 made 255 at 12psi (at 4,500) on the same dyno with tune, n1 turbos, cam gears, big exhaust but otherwise all standard so the v37 is likely a little better out of the box. One thing that is very clear is that the standard water to air intercoolers are not up to sustained use at full throttle in warm ambient temps. After about 5 runs (so only a few minutes full throttle), it was pulling boost and timing and dropping 10-15% power. Unfortunately I didn't get that printout and the Unigroup guys are away at the moment, will try and get hold of it on their return. So, looks like a healthy engine to start modifying and the only real area of concern is the w2a heat exchangers which the aftermarket has plenty of solutions for
    • I maintain it actually looked really nice in person. So much so that I thought "No, this is illegal" but there it was, clear as day. I think we can easily call the wing and wheels/height to be transformative. Not saying it's better than the GR Whatever, or the 86, or the WRX STI or anything of that sort (the internet says it all bolts up so you can buy best of all worlds?) but it's still at least a thing and not nearly AS bad as people say.
    • That's less offensive than the previous gen.....except for all that ugly black tupperware around the edges. Blerck!
