1. Stock front pipes off r33 gtr, should also fit r32 and r34?
Good condition for age. Heat shield is scratched up but pipes are fine. Flexi pipe in good condition
$60
post-120608-0-24618100-1412901167_thumb.jpgpost-120608-0-57215100-1412901167_thumb.jpg
2. This exhaust was made recently to comply with EPA standards and so garanteed to be under legal db limit. It is in great condition with minimal scratches . Basically a new version of the original size exhaust
Was previously fitted to an R33 GTR and will also fit GTST
Exhaust is small, 2" inch diameter with resonator and large rear muffler and shiny 4" inch tip.
$200
post-120608-0-79047400-1412901335_thumb.jpgpost-120608-0-20731200-1412901336_thumb.jpg
3. Generic brand high flow cat. Came on the car when I bought it, looks relatively new and was told it flows much better than stock
Inlet and outlet both 2.5"
Should also bolt straight onto:
- Nissan S13
- Nissan Skyline R32 GTS-T
- Nissan Skyline R32 GTR
- Nissan Skyline R33 GTS-T
- Nissan Skyline R33 GTR
- Nissan Skyline R34 GTR
- Nissan Cefiro A31
- Nissan Laurel C33
- Nissan Stagea WGNC34
- Nissan 300ZX Z32
- Nissan Pulsar GTi-R
$50
4. Old high flow cat (assume jap brand as the exhaust had a jasma stamp on it but not sure )
Catalytic converter has stock size inlet but larger 3" inch outlet for better flow and to match a 3 inch cat back. Should also bolt straight up the the list of cars above.
$50
5. Stock dump/front pipe off an r33 gtst.
Used but in good condition, still has original heat shielding
$50
Contact me on zero415 549 514
Pickup from Lidcombe, NSW
    • Kaizo Industries put a VIN plate over where the Nissan plate would go. It was part of how they broke the law and attracted feds going after them.
