Daniel - 0414573854
Pick up or can deliver if local...
S.E. Suburbs Melbourne (Somerville, Mornington Peninsula) ...
Listing is for 2 Videocards sold together
Purchased: 23rd March 2012 -Receipt Available
Used in CrossFireX Configuration
Selling due to upgrading to new cards
Cards come in individiual Anti-Static bags / do not come with original boxes
Price negotiable
Thanks for looking!! - Please text. pm or call for any enquiries!
SAPPHIRE 7970 3GB GDDR5
The SAPPHIRE HD 7970 is the first graphics card in the world to incorporate the latest generation of GPU’s from AMD built in a new 28nm process and featuring the new GCN optimised graphics processing architecture. The HD 7970 is the most powerful single chip GPU ever built. It has a new internal structure with 32 compute units and a total of 2048 Stream processors. It ships with a core clock speed of 925MHz, and AMD Powertune technology allows enthusiasts to increase performance by overclocking. A new 384-bit high speed memory interface with over 264GB/sec memory bandwidth connects to a large 3GB array of the latest DDR5 memory.
Display Support 4 x
Output 1 x Dual-Link DVI
1 x HDMI (with 3D)
2 x Mini-DisplayPort
925 MHz Core Clock
28 nm Chip
2048 x Stream Processors
Video Memory 3072 MB Size
384 -bit GDDR5
5500 MHz Effective Memory Clock
Dimension 275(L) x 115(W) x 36(H) mm Size.
System Requirements
PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard.
2X75 Watt 6-pin PCI Express power connector is required for CrossFireX™ system.
1X75 Watt 6-pin PCI Express power connector is required.
Certified power supplies are recommended. Please refer to: http://support.amd.com/us/certified/power-supplies/Pages/listing.aspx
1024MBMinimum of system memory.
Installation software requires CD-ROM drive.
DVD playback requires DVD drive.
Blu-ray™ / HD DVD playback requires Blu-ray / HD DVD drive.
To support 3 displays, one of the monitors has to support DisplayPort.
500 Watt Power Supply is required.
1X150 Watt 8-pin PCI Express power connector is required.
2X150 Watt 8-pin PCI Express power connector is required for CrossFireX™ system.
Price negotiable
Thanks for looking!! - Please text, pm or call for any enquiries!
Edited by flano87
    • Vinyl paint always ends up coming off interior trim and looking like arse. For the a pillar trims.....just try cleaning them with fabric shampoo? Maybe ditto for the headliner.
    • Hi everyone, I'm generally new to DIY projects, and I've browsed this forum and watched a lot of youtube videos but still have a few questions   Firstly, how does spray painting interior hold up? in particular like vinyl parts, my current mode of thinking is to use methyl spirits to take off original paint, clean/prep well, light coats, no primer or clear coat    Secondly, what is recommended for the headliner and, for example (my car is a r34), the A-pillars which are some kind of other fabric material, do you think I would be successful at retrimming these? or would it be better to go down the blacking out via Dupli-Color Vinyl & Fabric Paint    Any other advice / tips / tricks for refreshing/modernising these interiors?    Thanks
    • As title says  Pm a photo with what u have  Type m style would be good As Hidding a thick front mount
    • Just note that when trying to find a short in a globe power supply, it is best to disconnect the globe as it will allow current through to earth. With it unplugged it is easier not to get confused. Also with the r32 wiring, the high beam has 2 power supplies (one when you push the switch forward and the other when you temporarily pull it back; so if it is the high beam blowing you will need to trace both circuits
    • $75 Location: Gold Coast  Can post via Australia post
