I'm replacing the Weldon with a Fuelab which will give me some room to put the cool next to the surge tank which will have a thermo fan triggered by the ecu at a set temp and be protected by the rear diffuser
Off topic
ut where are you getting the fuelab from?
On the subject of the E85 getting warm, run a cooler under the car where the airflow can cool it and splice it into the return line (low pressure side).
Vehicles like M3's use that setup.
The only issue with a fuel cooler is mounting it in a suitably safe and protected way. Takes a bit more planning than an oil cooler etc.
Exactly !!!, that is why I haven't put one on yet, as my tuner said, I am better off burning an engine then you the whole car
But with what happened at the trackday I need to fit one, my idea is to mount it next to the fuel pump under the back and have the return line run through it then into surge tank and have the factory rear diffuser protect it from flying debris
  • Like 1
Its possible to put it into a grilled or fluted box surround to protect it.
Yep. But the consequence of it getting damaged could be huge.
I just wanted to make the point it's certainly not as simple as whacking on a fuel cooler.
What would be great is a heat exchanger setup, with coolant pumped through a cooler in the fuel tank, then through an external cooler. If it gets damaged only coolant pisses out, car doesn't burn..... but that's in my too hard basket.
I find them quite up to date.
This is united
http://www.unitedpetroleum.com.au/united/fuel/ethanol-85/e85-store-list
This is Caltex
http://www.caltex.com.au/HelpCentre/Pages/CaltexFinder.aspx
Select e-flex in the finder and zoom in.
I found 2 in the newcastle area that sell e-flex.
One is in Charlestown and the other is in Hamilton
There's one that's been selling E85 in Ipswich in QLD for over 3 months that still isn't on that list, so i'm sure that there may be others in other states that aren't on there but do sell it? Would be good to have one somewhere between Syd and melb for example.
For reference this is a map I made from the united list in June
The bottom tank is still quite warm though.
What you want is to run the aircon lines to the fuel tank, and have it automatically switch on as required. :P
Probably a dumb question but what is making it hot in the first place, the pump ?
    • It only looks tidy, as most of the stuff that was on the whole back wall, is now in the trailer to go to the tip, or has been shoved in my 2.2x2.4m "Spare parts room", and now I can't get to anything in there Ha ha ha I could definitely do with a bit more space, but I'd just end up with your problems I'm going to enclose the car port beside the garage, and move a lot of stuff into it I think. OR... It will be setup as a fabrication area, and the main garage will have parts storage in it. I'm not sure yet... Need some pictures of that big shed you've got with the bikes and Skyline in
    • No. I think it's gone. 😭 I think you can get body coloured ones on eBay so I think I'll get one of those... Or just hang a red ribbon from the hole and whack a TOW sticker next to it.
    • Can't say I've had a bad experience with one on my car, then again it only gets washed once or twice a year... The wheels on the other hand, get a good spray often due to my shitty dusty pads.
    • @MBS206 thats pretty neat and tidy to me!  I'll get a photo of mine when I'm out there next. It might require multiple photos to understand the scale of the atrocities though... In total I have 4 sheds of varying sizes and layouts. Main shed is 14x8, second shed is 3x8, third shed is 11x2.5, fourth shed is around 6x4.  All are pretty much full.   The main goal of my cleaning tsunami is to make the main shed predominantly car and motorbikes only. Second shed is my metal fab room (2 x bench grinders, drill press, bench belt sander, metal band saw, scrap metal storage and some of my garden tools.  3rd shed is more bigger garden stuff, storage for engine crane, jack stands, concrete grinder, concrete mixer, air compressor lives there, and it now has two 2mx2m pallet racking shelves with itemised boxes holding building stuff, electrical stuff, plumbing stuff, etc, etc.  The 4th shed is Ryobi electric ride on mower, mini boom sprayer, ancient Kubota tractor, more garden stuff!  I have got a lot of shit....  Then there's the pool house (8mx4m) and the pool pump shed (4mx4m).  I built all of the sheds over the 11 years we've been here.  The main shed was a Ranbuild kit, the rest are all custom made to fit the areas available. Building the main shed taught me a LOT as I had no idea about building anything prior to that!  I've still got one more in me. It will be my man cave which I poured the extra concrete for way back when I poured the concrete for the main shed. The idea is the Skyline will be a centre piece of the main cave once (if...) it's finished.  I told my now 14 year old son yesterday that I will 100% drive him to his year 10 formal in 2 years. Still a long way off but at least I now have a date to work towards! 🤣
    • Modern oils are amazing. Add tyres to that as well.
