Hello all,
I have scored another 32moredoor gts4(scored it mega cheap...), when I bought it the engine had been played with.
Has had FFP and topmount td06-20g-external gate installed, fmic, stock injectors, stock coilpacks, stock afm(green label), stock ecu(still untuned after installs).
I have seen the car running before all installs and it was mint.
Has also had alarm/immobiliser and switch to disengage the front diff installed (have herd of immobiliser screwing with some cars)
On cold start I have to feed it to get it to start and idle which it only just does, once running it struggles to run, misses like crazy(sounds like a rough subaru) and overfuels(can smell it) sits on about 500rpm then stalls out.
Ecu is telling me code 43 but I have had multimeter on the TPS wiring and all is good voltage wise but nothing changes when its running and I disconnect the plugs on the side. Has been swapped out for a known working tps and same problem.
Didnt think a turbo and plenum swap would throw everything out so much???
Blows a bit of white smoke which im guessing is fuel.
Havent kept it alive long enough to get warm incase its something major.
All the coilpacks are fine and plugs seem to be ok aswell, swapped out ignitor and no change
Also there is NO change in idle etc when I unplug the AAC etc...
I have looked into most things and am about to send it to a shop but would rather save the $$$ for when I get nistune/afm/injectors/TUNE but dont want to do all that and find out the motor is ROOTED!!!!
I attached a before and after of the engine, did a massive tidy up/clean while trying to find the root of the problem, has all new vac lines etc now. Can upload a video of it trying to run if that may help.
https://www.sau.com.au/forums/topic/449625-rb20det-help-please/
unfortunately for you, running aftermarket turbos on the factory ecu can make the engine grenade on boost. I would suggest a comp test at the minimum.
Check AFM wiring, and maybe for vac leaks. Although a vac leak usually leads to a high and lean idle.
white smoke is usually a bad indication but it could have been condensation in the exhaust if the engine hasn't fully warmed up yet.
note; if you do a comp test don't forget a wet test as well to get an idea of the piston ring condition
So did the car get hammered with the new stuff on it or just started and it was running crap?
As Blackkers said if it got a hard time with the new turbo etc it would have easily killed the engine.
Coming from an sr20 background I have been lookign at the pvc and aac scraching my head actually.....looking at all the treads about these and they just make me scrach my head more lol....
I have a broken hand atm so having trouble pulling it apart so havent gotten to taking the pvc out
The whole plenum set up has me scraching my head actually. Been wondering if having ALL vac lines for wastegate etc coming straight out of the plenum might be confusing the ecu a bit? not currently running a bov so no vac in cooler piping only the 3 coming out of the plenum as you can see in pics....
had a little tinker before and pulled aac off and cleaned it (was sooo full of carbon) then set the idle on the side of that which had it running a bee's d!ck better
Your pcv setup won't be helping.
^^^ Agree, is there even a PCV valve there? looks just like a fitting then hose to rocker cover. Will be sucking un metered air.
You mean the fitting on the firefall side of the ffp?
Edited by Noddy42
I think they might be concerned by the open breathers on the cam covers.
If you are from an SR20 background, then setting up the various connections on an FFP on an RB should be simply a case of making them look and do what they do on an SR. Same things have to go the same places.
Thats easy enough then, should be all good.
Will block them all bar one and see what that does
You guys where spot on, the pvc valve is still in the stock plenum and thats just a open fitting...... going to change it now. Cheers guys
By the way. It's PCV, not PVC. PVC is a type of plastic.
LOL sorry.... to much pvc at work.
PCV was some of the problem, noticable differance, now it starts/turns over and stalls straight away, I can baby it at 1000rpm but as soon as foot comes off it stalls. WAY WAY less fuel smell now but a hint still there.
Thanks shitloads guys,
still getting the error code 43/tps wiring tho.... anyone know of anything else that would cause that to come up? voltages for the tps seem sweet as and has been swapped for known working one.
Whoever did the plumbing of the all vac lines & breather lines should be revoked of his man hood and grow a vagina..
You need to plumb back OR block the PCV line going back into the plenum as the car is still running an AFM.
  • Like 1
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
