Hi everyone,
All the following parts are from my 1995 Series 1 R33 GTR V Spec, following a recent upgrade.
Please refer photo's for what's included with each item.
DBA 4000 Rotors (4298SL) Front (when new 324mm x 30mm) Rear (new 300mm x 22mm), with Endless CCX pads (BL12BL rear, BL09BL front), stock R33 GTR callipers & lines. $1,400.
Stock R33 GTR twin turbos, off running engine set to 1 bar boost. Minimal shaft play & appear pretty good condition. Includes actuator, dump pipes & heat shields. 85,000kms old. $200.
R33 RB26 14 x standard head studs. $40.
R33 RB26 6 x standard injectors. $60.
R33 RB26 water pump. $20.
R33 RB26 oil pump. $90.
R33 RB26 6 x pistons & 5 1/2 x rods (No freakin idea what happened to the other half of the rod! Turned my place upside down looking for it.) $100.
R33 RB26 6 x standard coil packs. $100.
R33 RB26 cam gears. $40.
R33 RB26 tension & idler pulleys. $50.
R33 RB26 standard harmonic balancer. $50.
R33 RB26 crank angle sensor. $150.
HKS EVC IV (Electronic Valve Controller/Boost controller). $290.
R33 GTR Power FC & hand controller. $700.
I live in Rockdale NSW.
PM me with any further inquiries.
PM's replied. A lot of interest in the Brembo's.
Initialdennis I will separate if someone doesn't buy the whole setup.
Nice teamwork guys, I have an interested buyer looking at them tonight. If unsuccessful I'll let you know.
Initialdennis, I went AP Racing & have never looked back! But as always it's dealers choice. Good luck hunting.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
