Hi everyone,
All the following parts are from my 1995 Series 1 R33 GTR V Spec, following a recent upgrade.
Please refer photo's for what's included with each item.
DBA 4000 Rotors (4298SL) Front (when new 324mm x 30mm) Rear (new 300mm x 22mm), with Endless CCX pads (BL12BL rear, BL09BL front), stock R33 GTR callipers & lines. $1,400.
Stock R33 GTR twin turbos, off running engine set to 1 bar boost. Minimal shaft play & appear pretty good condition. Includes actuator, dump pipes & heat shields. 85,000kms old. $200.
R33 RB26 14 x standard head studs. $40.
R33 RB26 6 x standard injectors. $60.
R33 RB26 water pump. $20.
R33 RB26 oil pump. $90.
R33 RB26 6 x pistons & 5 1/2 x rods (No freakin idea what happened to the other half of the rod! Turned my place upside down looking for it.) $100.
R33 RB26 6 x standard coil packs. $100.
R33 RB26 cam gears. $40.
R33 RB26 tension & idler pulleys. $50.
R33 RB26 standard harmonic balancer. $50.
R33 RB26 crank angle sensor. $150.
HKS EVC IV (Electronic Valve Controller/Boost controller). $290.
R33 GTR Power FC & hand controller. $700.
I live in Rockdale NSW.
PM me with any further inquiries.
PM's replied. A lot of interest in the Brembo's.
Initialdennis I will separate if someone doesn't buy the whole setup.
Nice teamwork guys, I have an interested buyer looking at them tonight. If unsuccessful I'll let you know.
Initialdennis, I went AP Racing & have never looked back! But as always it's dealers choice. Good luck hunting.
    • R12 has not been not available for....decades now. Propane is not a great replacement. (I mean, it's a great replacement, but it is a bit too flammable). R134a being the only way to go forward with an R12 system. The design pressures etc, are close enough to R12's to work. The ability to move heat around is close enough to R12's to work.
    • Out of curiosity, what's the reason for converting? I think @R3N3 might have the Frenchy's kit in the R33? I somehow think of you as the ambassador for realistic and clean street-driven setups nowadays
    • careful when running the car after a boil over. Ive heard you can lose enough coolant that it won't show the right temps because of too much air in the system (or something like that). Make sure the levels are good before trying again.  Maybe a mobile mechanic can come have a look with their scan tool ?
    • OK, just for some extra clarity - there is more than one option at Frenchy's. 1. You can buy the whole kit - with or without the actual compressor. The whole kit includes mounts, hoses, condensor, etc. That's either ~$2200 or ~$2800. No surgery required with this option. 2. You can buy just the bracket (~$600), or the bracket with the compressor (~$1200). Either of this or the above option "without the compressor" is if you already have an Echo comp or you are able to source one locally. Whatever the case, in this option, you will need surgery done on your hoses to adapt to the new compressor. When I said "the Frenchy's kit", I meant the whole kit in option 1. It is obviously somewhat more $$ than a $1500 OEM compressor. But if I had to spend $1500 on an OEM compressor, I would certainly consider spending double that to renew and significantly update everything forward of the firewall. Another option is to rebuild your original compressor. My R34 comp is currently dead and I will be most likely doing that to it if the spare one in the shed is also leaky.
    • I’m thinking that’s the route I’ll  go, thanks for the input!
