Alright want to get rid of the remainder of this stuff, so 50% off the rest. To be clear.......
Stock R33 GTR twin turbos, actuators, dump pipes, & heat shields. $100.
R33 RB26 14 x standard head studs $20.
R33 RB26 6 x standard injectors $30.
R33 RB26 water pump $10.
R33 RB26 oil pump $45.
R33 RB26 6 x pistons & 5 1/2 rods $50.
R33 RB26 6 x standard coil packs $50.
R33 RB26 cam gears $20.
R33 RB26 tension & idler pulleys $25.
R33 RB26 standard harmonic balancer $25.
Please refer above for pictures.
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
