Hey guys
How can i keep my stock dual tips but still be able to modify something to gain maximum gains or flow from it as well improving the RB note by not too much to attract negative attention but still an improvement over dead stock sound.
Stock looking is clean IMO :)
The rear muffler is massive and likely restrictive. Better option would be buy a similar but good rear muffler and use that.
Of course you could get the centre muffler removed and see how that goes, but your car won't go hard untill you get a decent turbo and exhaust.
Better option don't bother.
This is easy. Cut stock twin tips off of existing rear muffler. Weld them onto new twin tip rear muffler as part of complete exhaust replacement. Make new exhaust 3" with big centre muffler and big rear. Add 4" bodied 200 cell cat* and full length dump+front pipe.
* 200 cell 4" cat recommended so as to not get too illegal and loud. 5" bodied 100 cell cat for maximum fasts.
Possible, but very minor gains if any. You can replace the dump/front pipe with a 3" design, I favour the bellmouth as it gives plenty of space for post-turbo air to sort itself out. A higher flowing 200cpi cat is worthwhile too. However, the rest of the piping is 2.5" and has restrictive mufflers in it, this is good for quietness but not good for power.
You are best off talking to an exhaust shop to make something that looks factory (twin tips if you wish) and flows better than standard that isn't too loud.
I had a stainless 3" exhaust from turbo back made up with twin outlets. Cost just over a grand, and gave good gains on stock turbo (~185rwkW, pod, exhaust, nistune) while staying fairly quiet. One of the best mods bang for buck I've done.
  • Like 1
mild steel 3.5 inch turbo back with a single hooker mufler and de cat
I loved the sound mine made, soudned better than 90% of music on the radio too so i saved money not needed a sound system, woudlent be able to hear it anyway :)
You wouldn't last 5 minutes down in Melbourne. Haha.
The 3.5 inch Hooker mufflers have a 3 inch restrictor inside them, may as well go for a Chinese 3.5 inch muffler, it will flow better and probably be quieter.
Has anyone tried a Dynomax VT? The flap blocks off like a Varex, but opens on exhaust pressure. I assume it will make the setup a little laggy but it intrigues me a little. Decently priced at $150 odd too. Could make a good mid muffler if it isn't too restrictive when closed.
http://www.ebay.com.au/itm/191330618237?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Really? http://www.tuffcarparts.com/index.php?route=product/product&product_id=268
i know i put a 3 inch tip on it so it didnet look to big out the back but im sureits 3.5"inside
Shoudlent be much of a restirction with 340 od KW
Still, a better exhaust is on my list of things
I made 20-30 kw when I shoved the 3.5 Varex on the back, ditching the Hooker, but I did get rid of a few bends at the same time. It has a restrictor inside to accelerate the gasses, as part of it's chamber design.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
    • While it is a very nice idea to put card style AFMs into the charge pipe (post intercooler, obviously), the position of the AFM and the recirc valve relative to each other starts to become something that you really have to consider. The situation: The stock AFM is located upstream the turbo, and the recirc valve return is located between the AFM and the turbo inlet, aimed at the turbo inlet, so that it flows away from and not through the AFM. Thus, once metered air is not metered again, neither flowing forwards, or backwards, when vented out of the charge pipe. When you put the AFM between the turbo outlet and the TB, there is a volume of pressurised charge pipe upstream of the AFM and there is a volume of pressurised pipe downstream of the AFM. When the recirc valve opens and vents the charge pipe, air is going to flow from both ends of the charge pipe towards the recirc valve. If the recirc valve is in the stock location, then the section between it and the TB doesn't really matter here - you're not going to try to put the AFM in that piece of pipe. But the AFM will likely be somewhere between the intercooler and the recirc valve, So the entire charge pipe volume from that position (upstream of the AFM, back through the intercooler, to the turbo outlet) is going to flow through the AFM, get registered as combustion air, cause the ECU to fuel for it, but get dumped out of the recirc valve and you will end up with a typical BOV related rich spike. So ideally you want to put the AFM as close to the TB as possible (so, just upstream of the crossover pipe, assuming that the stock crossover is still in use, or, just before the TB if an FFP is being used) and locate the recirc valve at the turbo outlet. Recirc valve at the turbo outlet is the new normal for things like EFRs anyway. In the even of a recirc valve opening dumping all the air in the charge pipe, pretty much all of it is going to go backwards, from the TB to the recirc valve near the turbo outlet. But only a small portion of it (that between the TB and the AFM) will pass through the AFM, and it will pass through going backwards. The card style AFMs are somewhat more immune to reading flow that passes through them in reverse than older AFMs are, so you should absolutely minimise the rich pulse behaviour associated with the unavoidable outcome of having both a recirc valve and an AFM in the charge pipe.
    • Yep, in my case as soon as I started hearing weird noises I backed off the tension until it sounded normal again. Delicate balance between enough tension to avoid that cold start slip and too much damaging things.
    • I'm almost at a point where I feel like changing the alternator. Need to check the stuff you mentioned first though.
