Hey guys, looking at buying a 2 or 3 layer nomex suit and they are mega expensive. Even the 2 layer ones from Revolution are over $550.
Are there any other places in Sydney worth checking out? What about online is there a lot of money to be saved? Where should I be looking? My concern with going online is getting a suit that doesn't fit but if I'm paying half the price I'll run the risk and return if it need be.
Anyway keen to hear your thoughts.
https://www.sau.com.au/forums/topic/449770-where-to-buy-racewear/
http://www.racedeal.com/index.html
^These guys were very helpful. After meeting them at WTAC, I was very happy to purchase from them. They even pay for the return postage to exchange the suit for a different size.
If you can, go and check out the trade stands at this years WTAC.
Pro tip: Always order a size up from the size you measure up to. By the time you sit it your race seat the suit tends to ride up a bit.
  • Like 1
Damn it, they were at WTAC? lol
Ah well, taking a roadtrip out there next Saturday...
Sorry I ment in 2013. Not sure if they were there this year, as I couldn't get there myself. I just assumed they would be again?
Ah OK, i wandered around most of the stands and didnt see them... But its only a few hours away so am roadtripping there after i drop my car off at Road2Race on the weekend...
They have seats and steering wheels etc in stock to try out so its worth the drive! They seem pretty helpful so far over the phone and also came recommended from Boz :)
That is the Sparco Australia Distributor.
Address is 3 Pullman Place Emu Plains (#4 is the distribution warehouse).
Bought all my gear off them, just make sure you call before you leave home to make sure they will be open.
Nice! I called and booked a time with them as they are only open a few hours Saturday...
    • Have you put an aftermarket oil pressure gauge on and verified your oil pressure?   Noise being on the block, on exhaust side, how high up the block does it seem to be? It could be the VCT system getting cranky, especially if it's mainly at idle, and when warm, as that'll be your lowest point for oil pressure. Could be showing that oil passages / VCT solenoid are blocking.
    • Well, hydraulic lifters will get noisy if they are dirty/fouled in some way, and exactly how that manifests will depend on exactly what schmutz is where. There is a procedure on here somewhere for dismantling and soaking/cleaning them. Replacing them with new is about 50% of the work and about 5% of the money!
    • Thanks for the reply @GTSBoy this is is a hydraulic lifter engine. Yea right i did not realise the lifters were supposed to be compressible while installed. I could push them down but i had to lean almost my while body weight on them.  I have never heard of a lifter/ lifters ticking only at hot idle and getting worse the hotter it gets. I have owned a few jdm cars with noisy lifters. This noise is slightly more subtle, it is more of a sharp gentle metalic tic than the solid and more loud tapping I've heard on lifters. I have used a metal rod, alloy tube, hose and stethoscope and could not find the source of the tick. But it appears to be loudest on the actual engine block behind the exhaust cam gear and next to the oil filter. I had mate (40 year old mechanic) go over it with me and he couldn't find it either..  Could it be a cam seal issue of some sort?  Cheers
    • This seems problematic and unlikely at the same time. Vanilla RB2Xs have hydraulic lifters. They do have "zero" clearance, but only when running with oil pressure inside them. When not running, you should be able to compress them and obtain heaps of clearance. RB26s and Neos have solid lifters. They should have ~0.3mm and ~0.5mm on the inlet and exhaust respectively. If they have zero clearance then bad things are happening. With nothing else being wrong, it would mean that the valves would be held slightly (ever so slightly) open when they are supposed to be closed and it should have all sorts of problems when running, caused by leakage in/out through the valves. Or, zero clearance can indicate severe valve seat recession. None of it is good. Have you used a piece of hose as a stethoscope to try to localise the noise?
