I have a r32 with a stagea rb25det neo.
It isn't running right and im thinking maybe the ecu has something to do with it.
The r32 is manual converted.
The current ecu is 23740 0V300
I'm sure this is the 4wd auto stagea ecu.
if my car is rwd and manual, would the ecu possibly need to be changed to a different ecu?
https://www.sau.com.au/forums/topic/449772-wrong-ecu/
That's the wrong ecu. It doesn't matter if its manual or auto but the OV300 is a Hitachi ecu for a series 1 Stagea that has the R33 engine. You need a Jecs ecu for a series 2 Stagea which had the Neo engine such as .23710 aa501 (or an R34 GTT ecu).
https://www.sau.com.au/forums/topic/449772-wrong-ecu/#findComment-7409874
That's the wrong ecu. It doesn't matter if its manual or auto but the OV300 is for a series 1 Stagea that has the R33 engine. You need an ecu for a series 2 Stagea which had the Neo engine (or an R34 GTT ecu).
Yup says ov300, that would explain why its running so crap, doesn't like to boost. If i was to get a the neo ecu, would it be hard to swap over?
https://www.sau.com.au/forums/topic/449772-wrong-ecu/#findComment-7409881
If the car runs then I doubt the ecu is your issue.
I would open one thread with ALL the information so you can get some help.
Actually, if the car runs, and is notionally a Neo engine using an R33 era ECU.....what's the chances of it being all normal stuff in there? I thought the ECU pinout was different between R33 era stuff and R34 era stuff. There are certainly different devices (like the boost sensor) on Neo stuff. If the engine is being run by an R33 style ECU, then it's quite possible that some sensors and stuff have been changed or rewired on the Neo engine.
This car needs to be put in front of an expert who can look at it all at once and work out what it is and what to do with it. These piecemeal threads on this car are not helping. Advice I gave in the other thread about Nistuning the ECU will be invalid if it turns out to be an R33 ECU!!!!!!!
Edited by GTSBoy
https://www.sau.com.au/forums/topic/449772-wrong-ecu/#findComment-7409936
Photos with rose tinted glasses perhaps?
The engine is not from a 4WD stagea. Traction control rules that out. The ECU, if the lid matches the contents, is definitely from the early S1 Stagea. That should not plug into a Neo ECU loom plug.
You definitely have some sort of bitsa going on there.
https://www.sau.com.au/forums/topic/449772-wrong-ecu/#findComment-7410399
Yea i'm really confused, what is the engine from do you know? i'm taking it a expert tomorrow
https://www.sau.com.au/forums/topic/449772-wrong-ecu/#findComment-7410403
You also have that ling long turbo.
Why so many threads on all these problems? I think guys should have one thread "my car is a mechanical abortion"
Go out and get a power fc or something tunable so that you can make it run the way it should. Unless you know you have low compression in the motor and didn't check it before purchase.
https://www.sau.com.au/forums/topic/449772-wrong-ecu/#findComment-7410529
    • That ring thing is interesting how it's holding everything together
    • Hey guys. I have a 400R on its way to Australia from Japan currently and have a few questions I’m hoping others may be able to help with.   Wondering if anyone here has had any luck getting the Sat nav unit to work in Australia!? Assuming the Stereo is as simple as a band expanded and tv won’t work?  Seeing as they’re based off a Q50 which is Aus delivered is there any way to link that system to the nav? Nav modules and head unit are different part numbers and appear slightly different at the rear with plug ins etc. can I put my xtrail sd card into the rv37 and will that convert the maps or update to Australian? Has anyone got any advice here?     also has anyone fitted the factory remote start and Security system once it’s landed in Australia? I put an enquirey to Nissan Japan in via a third party, and they suggested it needs a Nissan Japan dealers device to setup and couldn’t guarantee if one here could do it or not. They can supply and I can physically fit it but to setup I would need a dealers device. Any information here would be appreciated also. I’ve seen one here with it fitted already prior to leaving Japan at a dealer/inporter, so clearly passes compliance and works when fitted Japan and doesn’t need changing here.      also, does the tyre inflation sensors work here? Does anything change with them when the vehicle arrives? Where are they actually situated? I’ve read they have batteries and they need to changing at times and seems like resetting involves the nav system?    any help here would be appreciated and any other aust specific information to help would be great. Looking forward to see what the current generation skyline is like and eager to see how many of the gadgets can be utilised here.  Thanks in advance
    • Do need to take it with a pinch of salt. One of the adapter failures, they clearly had setup issues with the flywheel.  One of the slipping ones I spoke to and it was pretty clear the throwout was riding, rather than fix, just swapped to a new clutch.    These clutches are being put in anything from 5k offroad 4x4 beaters, GR yaris, 500hp commodores to 1200hp barra monsters. Bound to be some issues in some of them when they are not a simple bolt in affair due to the changes in height.    There is a lot going on in this picture and unless I did the job myself no way to tell what really happened.
    • I did this mod in 2019  You just have to modify the top bracket of the ABS/TC/Fuel Pump Control ECU so it sits more upright and closer to the back seat and run a good quality positive battery lead from the engine bay, the negative lead i just bolted down to the body in the boot.
    • Damn... Not the feedback I want to hear.
