Hi Folks,
I have some R34 Standard bits and pieces that I do not need. I was going to post up more, but some of it (not listed) is still stuck on the car because the engine blew up and it's in a workshop.
So please buy some of it so I can afford to get it fixed thanks.
Note: I am unsure on some pricing. If you see it elsewhere listed for less, sold for less in the past etc, just PM me and I will adjust to suit.
THE PANELS ARE IN KV2 PAINT COLOR
Left and Right Front Guards $300
Bonnet+ Latches etc $180
Front Plastic Guards for infront of Wheels (pair) $90
Reo Bar 200 (just the actual bar, not the headlight supports, unless you want free S2 headlight supports)
Front Bar (series 2, headlight supports can be thrown in to fit it) 100
Headlights (pair) $300
Front Wipers $40
4x Stock Wheels (brand new tyres, literally 5km on them) $400
Window Switches FOR A SEDAN - All 4 doors. $60
Head Unit (Clarion, its blue.. it works... etc) $40
R34 Auto Transmission $150 - This is in retardedly un-farked condition. Believe me, I'm from the internet.
Radiator 80
Radiator Shroud 50
(please take them both)
STD Front Sway Bar 40
Front Indicators (series 1) 40
Sedan Rear Lights 150
R34 Stock Turbo Triple gauges + plug $100?
R34 Indicator Stalk $40
R34 AUTO clock spring $100
R34 Front Strut Brace $40?
VDO Digital Oil temperature gauge. 52mm. Works perfectly. $60
I'd really, really, really, really, really, really prefer pickup over sending them. Unless you want like, the entire front end in which case i'll lop the price off and send it.
https://www.sau.com.au/forums/topic/449794-vic-r34-stock-stuff/
  • 3 weeks later...
  • 2 months later...
  • 4 months later...
Right. Figured I'd bump this.
Still have the following!
Bonnet + Latches etc $200
Reo Bar $200 (just the actual bar, not the headlight supports, unless you want free S2 headlight supports)
Front Bar (series 2, headlight supports can be thrown in to fit it) $80
Front Wipers $40
Front Indicators (series 1) $40
Sedan Rear Lights $150
Radiator + Radiator Shroud $120, No leaks, works perfectly.
1 DIN Head Unit (Clarion, its blue.. it works... etc) $40
Climate Unit Computer thing and center surround - $80
Stock Front Sway Bar $30
VDO Digital Oil temperature gauge. 52mm. Works perfectly. $50
R34 AUTOMATIC clock spring $100
R34 AUTOMATIC dash cluster, 100,000ish kms. All works. $100?
Everything rather negotiable. As in, really very negotiable.
In Glen Waverley, VIC.
  • 3 weeks later...
Reo Bar $200 (just the actual bar in the center, not headlight supports - this is the bit people cut for FMIC's)
Front Wipers $40
This is what I still have.
(i.e no headlights, only tail lights now... and an excuse for a bump)
  • 1 month later...
  • 3 weeks later...
Totes sold a strut brace.
Also for you auto guys out there that have somehow killed your Torque converter (i.e - Noone ever) I have a rebuilt torque converter because ... reasons.
I'm 95% sure that I do - But these are headlight supports for series II - They are not the same for a series 1 front bar, and will not fit :P
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
    • appreciated it thanks   There are threads on the adaptor. I rear re anodising but didn’t know it will reduce strength   re mating services needing to be flat/ not painted, why would that be? I am devastated as car been off for a year, fixed power steering then installed bm57 master cylinder and just before driving it this came up. So annoyed   worried and afraid to drive it, no fun caliper coming off
    • Just report the OP (via the 3 dots menu at the top right of post) and request deletion.
    • And boosters can be rebuilt by the same sort of brake shops that will rebuild a brake booster.
