Looking for a cheap reliable race car. this will be a dedicated race car. what are people opinions about this set up. Im not wanting to be competitive just have fun. Looking to enter hill climbs, super sprints etc. No door to door racing atm. I just sold my r33 GTR and cost me quite a bit in repairs. i Just want to start getting in the sport and not be always worried about breaking the car. My thinking is that if i stay away from forced induction, then there would be less things to go wrong. Less pressure on the motor. with an LS1 its easier to fix.
Weight will probably be lighter as well, with loads of torque. with bolt on mods could easily achieve a reliable 400hp. Don't factor in conversion costs of the V8.
https://www.sau.com.au/forums/topic/449805-r33-with-an-ls1/
There used to be a v8 r32 getting around but I am pretty sure it was sold on and not sure where it got to. It had a solid 300kw, was very set up and went nicely.
And if you want to save some money on the idea MBS026 on these forums has a half finished one you could probably look at starting with
https://www.sau.com.au/forums/topic/449805-r33-with-an-ls1/#findComment-7410650
Good luck cheap and race car don't go togeather..... Unless you and spanner yourself.
Have you ever tracked or raced a car before? If not try something under powered and good handling. I started in a stock mx5, best bang for buck track car bar none. Your mate will hang s#it on you till you beat them...
Skylines are big heavy and handle like a turd... But bucket loads of fun on the track.... Can't see a v8 one been cheap... The weapon of choice these days seem to be evos. Go well, sound and look like s#it. I.M.O.
Give me a RB on boost any day....
  • Like 1
https://www.sau.com.au/forums/topic/449805-r33-with-an-ls1/#findComment-7410738
i know i sound like a knob but the car already has the ls1 in it and the car is cheap. Ive been traking my GTR for 3 years, going to track day events, now i want to start getting into some competition events. Alot of the cars i have been around, many of the issues are to do with the turbo/intercooler/boost. so my thinking is the less you have, the more reliable its going to be. When i say cheap its all realative i guess. looking around the 10-20 grand.
https://www.sau.com.au/forums/topic/449805-r33-with-an-ls1/#findComment-7410806
There is undeniably some merit in the idea.
With some thought and attention to detail, an LS / R chassis marriage could work, with better weight distribution and the same sort of power output (if different delivery) as something with the RB engine.
If you don't care what people who don't know any better have to say, then an MX5 is top of the tree. And if you want to go fast, then an Evo is the pick.
https://www.sau.com.au/forums/topic/449805-r33-with-an-ls1/#findComment-7410880
I love the LS engines, and I agree that an LS R33 could be a good thing. Just be aware that you might limit your choices in competition, as most categories wont allow this type of engine swap, unless you're in the open class against sports sedans.
+1 on a cheap, fun track car. Because nobody has said it yet, I'm going to chime in with my usual EK / EG Civic or DC2 Integra. Barrels of fun (very neutral handling despite what the uneducated anti FWD keyboard warriors say) and reasonable power to weight. If you want to spend a few extra $$ you can pick up a K swapped Civic / Integra which gives you the potential for a reliable 200-250 HP at the wheels. Plenty for a FWD buzzbox that weighs nothing.
Remember, the easiest way to gain speed is to lose weight (the car, not you). Start with something light and well balanced and you don't have to go nuts with mods to get a fun, quick car.
  • Like 1
https://www.sau.com.au/forums/topic/449805-r33-with-an-ls1/#findComment-7410938
You don't sound like a knob.... Tracking a GTR R33 must of made your wallet bleed.
https://www.sau.com.au/forums/topic/449805-r33-with-an-ls1/#findComment-7411047
i don't mind spending the money but once your afraid of driving the car hard because you don't want anything to break is not my idea of fun. at the top of the list for me is a s14. Reason why iOS that i really like circuit racing but want to try and learn how to drift as well
https://www.sau.com.au/forums/topic/449805-r33-with-an-ls1/#findComment-7411107
^ shows an LS fits but how much is it extended past straight lining?
Credit to the owner, and a good looking unit should be fun but would struggle to match an Evo or MX5 anywhere there's bends. Warps also makes valid points about the Honda platforms.
An R chassis / LS combination would be a hoot to drive and a real talking point, but I figure the others easier to set up due to collective knowledge on the things.
All that said, if I was to re-power my 33, it would get an LS...
https://www.sau.com.au/forums/topic/449805-r33-with-an-ls1/#findComment-7411951
I was thinking about buying this
http://www.gumtree.com.au/s-ad/logan-village/cars-vans-utes/nissan-skyline-v8-r33/1056223037
This car still needs a lot of gear as it only has the conversion, but thought it would be a good start.
  • Like 1
https://www.sau.com.au/forums/topic/449805-r33-with-an-ls1/#findComment-7412775
From someone who has a half built LS1 into an R33 for track purposes, you really need to listen to Warps. You will instantly limit your choices of what/where you can enter to race.
You end up in sports sedans if under CAMS, or in the full on open categorys under anything else. From memory with drifting they've else banned engine swaps from different manufacturers.
That being said, they look great, and sound spastic. If I remember correctly, before the suspension was fully sorted on Stu's R32 LS1 he gave the keys to someone and it went a 1:02 or 1:03 around Wakefield.
https://www.sau.com.au/forums/topic/449805-r33-with-an-ls1/#findComment-7413878
    • Very nice - I also have a 92 GTST and hardly see any others around these days
    • When I need something else to edit, I use Movavi. A friend who does video editing on a daily basis recommended me) it's an easy video cutter to use for beginners
    • I need to edit some videos for work but I'm not good at all this. Which video editor can you recommend?
    • I think you're really missing the point. The spec is just the minimum spec that the fuel has to meet. The additive packages can, and do, go above that minimum if the fuel brand feels they need/want to. And so you get BP Ultimate or Shell Ultra (or whatever they call it) making promises to clean your engine better than the standard stuff....simply because they do actually put better additive packages in there. They do not waste special sauce on the plebian fuel if they can avoid it. I didn't say "energy density". I just said "density". That's right, the specific gravity (if you want to use a really shit old imperial description for mass per unit volume). The density being higher indicates a number of things, from reduces oxygen content, to increased numbers of double bonds or cyclic components. That then just happens to flow on to the calorific value on a volume basis being correspondingly higher. The calorific value on a mass basis barely changes, because almost all hydrocarbon materials have a very similar CV per kg. But whatever - the end result is that you do get a bit more energy per litre, which helps to offset some of the sting of the massive price bump over 91. I can go you one better than "I used to work at a fuel station". I had uni lecturers who worked at the Pt Stanvac refinery (at the time they were lecturing, as industry specialist lecturers) who were quite candid about the business. And granted, that was 30+ years ago, and you might note that I have stated above that I think the industry has since collected together near the bottom (quite like ISPs, when you think about it). Oh, did I mention that I am quite literally a combustion engineer? I'm designing (well, actually, trying to avoid designing and trying to make the junior engineer do it) a heavy fuel oil firing system for a cement plant in fricking Iraq, this week. Last week it was natural gas fired this-that. The week before it was LPG fired anode furnaces for a copper smelter (well, the burners for them, not the actual furnaces, which are just big dumb steel). I'm kinda all over fuels.
    • Well my freshly rebuilt RB25DET Neo went bang 1000kms in, completely fried big end bearing in cylinder 1 so bad my engine seized. No knocking or oil pressure issue prior to this happening, all happened within less than a second. Had Nitto oil pump, 8L baffled sump, head drain, oil restrictors, the lot put in to prevent me spinning a bearing like i did to need the rebuild. Mechanic that looked after the works has no idea what caused it. Reckoned it may have been bearing clearance wrong in cylinder 1 we have no idea. Machinist who did the work reckoned it was something on the mechanic. Anyway thats between them, i had no part in it, just paid the money Curiosity question, does the oil system on RB’s go sump > oil pump > filter > around engine? If so, if you had a leak on an oil filter relocation plate, say sump > oil pump > filter > LEAK > around engine would this cause a low oil pressure reading if the sensors was before the filter?   TIA
