How experienced are you building engines?
First time? Based on the incredibly vague first question that's what I assume.
Comp ratio is a compromise relating to many factors. Boost, fuel, cams, head design etc.
Certainly not as simple as what's the best.
Although 500whp isn't that much so stock comp would do it with that turbo and fuel I imagine.
Hi Ben c34 yeah I am new to these engines as I have only owned mazda rotaries (complete different animal). But from the info I have gathered I have been told a stock cylinder head should be ok for what I am doing but I need to upgrade rods and pistons as well as mod crank snout for the longer oil gear. But I am probably going to stick with stock compression ratio.
Thanks
Richard
Yeah I am in the states and the places that sell en are like 45 minutes away. But thanks for all the info. Btw When using the stock head and stock head components what parts are known to have problems and If I did want extra insurance I am assuming just install valves and retainers.
Edited by ricardo.benin
Hi I am having the head reconditioned for sure. Then I was going to clean up cast marks in ports but mainly water jacket holes in cylinder head and I was thinking of running a line from cylinder head to sump. And widen the oil galleries on head and block.
I think a GT3582R will be quite laggy on an RB25 with the std CR on your 93 octane . In the US with things like the 3076 and 3582 HTAs available I think you can do better .
With non standard manifolds the EFRs are probably better again particularly on pump gas because their turbines tend to be larger in relation to their compressors than most other turbo suppliers . You should be able to get 500 from a 7064 or a 7670 with better turbine response/transients than most other makes .
Having less inertia and exhaust restriction is the go IMO .
A .
I was talking specifically about the lifters.
    • I went from stupid 600+HP setup, to an NA Barra in mine...
    • You have the option to do this. Nobody but me ever did this (go slower, I mean) Everyone seems to fall victim to "This would be a great setup for you, but for me, I need a little more power..."
    • Save yourself the headache of an alarm. Immobilizer on the signal side of the main EFI relays so it won't start is good enough. DIY killswitch is the same thing except instead of a nice passive system you need to remember to switch it on and off.
    • Yeah, the advent of canbus was supposed to cut down on wiring weight, then some bright marketing wonk says "oh, look at all these wonderful tech gadgets we can cram in here now that we have this wonderous technology" and some arsehole safety legislator says "oh, look at all the wonderful surveillance and tracking gadgets we can cram in here now that we have this wonderous technology" and some dipshit young engineer who has grown up thinking that an extra 500000 lines of code is not a problem because storage is cheap these days says "oh look at all this wonderful shit I can do to one up those dipshit arsholes over at VW" and the Karens of the world all go "oh look at all these fancy things I can do on my screen (so long as I am not driving on a bumpy road wherein touch screens immediately become the single most stupid shit idea ever shoveled into a car) and my 19 zone airconditioning keeps my sweaty fat folds a bit less damp and the windows close themselves because I'm too fat and lazy to wind them up for myself and these reversing sensors would have been great if I'd paid attention to them instead of smashing them on the bollard while I was reversing and staring fixedly forward that day I went to pick up little Charlize from ballet" and the sweaty mongoloids who say "oh this wonderful collision avoidance technology with these 45 excellent radar antennae scattered across the front of my car mean I can tailgate like a methed up tradie at full speed with no fear because the car and the 35 airbags will protect me if it all goes wrong" ...... </shallistopranting?>
