Hi everyone,
I've been a member for awhile mostly just browsing and reading different topics etc over the years, however I recently purchased a r33 gtst s2 and want to start a build. I have read a wealth of info most of which is very helpful and some of which get abit confusing and drift off topic lol.
Basically the r33 will be a car to get a project going to get a feel for the skylines and gain some experience before jumping on to a gtr and going all out. I've been involved with drag racing before and did a xr6t build which was good but I wanted to try something different and start a new project.
The r33 as it sits has the following mods
Greddy Front mount
Power fc
3inch exhaust
Hd clutch
Hks bov
The aim for my build is 600rwhp ( I know power is not everything but it helps to know where you heading lol)
I'll be doing full rebuild with Pistons, rods, cams etc
Greddy manifold with injectors
Upgrade the turbo not sure what yet
Coilpacks splitfires
Upgrade brakes
Suspensions not sure either
Fuel system upgrades not sure either
I need some advice on how to exactly go about it. I don't really have a budget but I don't want it costing crazy figures either.
with roughly 600hp what sort of suspension and tyre setup would you need to get it sticking? Mickey thompsons?
anyone here has a 600rwhp r33 and what sort of time are you getting? Any advice or experience anyone can share would be great.
Appreciate the help and advice
Cheers
Abz
https://www.sau.com.au/forums/topic/449854-r33-s2-build/
BC BR seem to be very popular, im yet to test mine out but give me a week or so and il let you know.
Otherwise if you ahve the extra $$ to sepnd get a good shock and srping set up, like the SydneyKid Bilstien kit
Fuel set up you need to decisde if oyu want E85 or 98 fuel. This will determine if you keen the Power FC or upgrafe to Dejetro ect for a dual map ECU
For rubber, up to you man test a few and update our trye thread :) but Federal RSR are popular with a good price tag
Stock GTR brake kit should do, again depends on budget. If you have the spare 3k odd then grab a good set of 8 pots and slotted rotors with braided lines
https://www.sau.com.au/forums/topic/449854-r33-s2-build/#findComment-7411629
Thanks for the reply guys
I was thinking 98 for fuel
With turbos is it best to keep with a brand name Garrett, Hks etc? or are these cheaper so called gt turbos worth a try? Is it a case of you get what you pay for?
I've been looking on prices and there's such a huge difference price wise.
https://www.sau.com.au/forums/topic/449854-r33-s2-build/#findComment-7411704
With turbos you do get what you pay for.....except for the few exceptions.
Examples.
Garrett turbos are at the top of the price range for turbos that are not pushing any performance boundaries.
HKS are slightly better than Garrett in some cases, same as Garrett in many cases. Have HKS tax on top of Garrett pricing.
Our own local friend Hypergear does a lot of turbo development for RB turbos and so his designs are pushing the boundaries of what is possible in terms of both response and power per frame size. And his prices are excellent because his overheads are under control.
GT Pumps and quite a number of other crowds that push out own made or modified turbos lie somewhere between those two extremes in terms of value and performance. Some push way past what Garrent stock stuff costs, but get you more performance - so value is acceptable. Just a little hard to swallow the purchase cost for some.
Ebay specials in the low hundreds are to be avoided unless you have little care about the result (both in terms of outright performance and what happens when shit goes bang). Anyone selling turbos claiming top performance at prices lower than Hypergear should be viewed with some cynicism!
https://www.sau.com.au/forums/topic/449854-r33-s2-build/#findComment-7411708
A bloke on here used to have a 500rwkw r33 gtst, he said it was fun to drive(when it could be tamed), however on the track, every corner he would be going sideways cause there wasnt any real traction when unleashing 500rwkw, stock cars would actually be on his ass during the bends haha. Before selling he switched back to stock and actually found it much more fun to drive(still running much more power than stock), since he had more response, and he could full throttle without the fear of stacking.
Anyways, reason i told you that was because you said you want to get a feel for skylines before getting a gtr, you'd probably enjoy just building the car for response, tweak the suspension, racing seats, etc.... rather than building a 600hp beast which will need a whole load of $$ to get it reliably making power on 98. 600hp would be more fun in a GTR than a Gtst (dont get me wrong, still fun in a GTST :D).
https://www.sau.com.au/forums/topic/449854-r33-s2-build/#findComment-7411762
I know exactly what you mean, traction was an issue with the xr6t build aswell and gtrs would be the best way to go but since I've got the gtst for now I think it can be manageable with a good suspension and tyre setup for the drags for the gtst .. I'm not experienced with rwd skylines as yet, so I'm basing this only on my experience with the xr6t and hoping to gain more info from this topic and other searches on this forum.
With regards to turbos and hypergear specifecally which of their kits would possibly deliver that sort of reliable power?
I heard bout them pretty much from this forum and gtsboy's post and had a look at the website
The highest rated turbo which I came across has 600hp which wouldn't equate to 600rwhp. Has anyone here used hypergear for a 600hp build and which setup have you gone with?
Would a manifold be necassary to go with the turbo or a direct bolt on would suffice? Also would the current 3inch exhaust be ok?
Cheers
https://www.sau.com.au/forums/topic/449854-r33-s2-build/#findComment-7411890
You will be trying for a long time to get traction in a Skyline with 600 @whp. No matter what you do with the suspension and the tyres.
You should PM Stao from HG yourself and ask what he can do for you. You should also ask his opinion on what 600 at the treads will be like, because he has pushed his dev mule R33 pretty far and lived to tell the tale. The tale is mostly about wheelspin!
https://www.sau.com.au/forums/topic/449854-r33-s2-build/#findComment-7411944
If you want to use this car as a practice before you buy a GTR, I dont really understand why you didn't just buy a GTR, start off small and work your way up to an extreme setup. You can do a forged, High horsepower engine build, then slap standard turbos etc on it. Then you are free to chuck a turbo at it when you want to etc.
Sorry I'm not being much help, but I dont really understand why you want to waste money doing it once on a GTS-t if your only going to go and upgrade to a GTR later anyway. I'm in too deep now that I can't switch to a GTR, the thought sometimes crosses my mind that I should have just got a GTR, but I like my car far to much.
https://www.sau.com.au/forums/topic/449854-r33-s2-build/#findComment-7411962
Agreed but I've got it now and got some parts already so I'll go through with it and see where I end up.
Had a pm chat with Stao and the recommendation was a hypergear atr45ss
Would anyone know if the standard diff are good for drags or that type of power?
There's Alot of confusion with the whole 1.5, 2 way nismo, kaaz, Cusco etc.
What's a good setup for the drags that's realible for that sort of power?
What sort of power can the stock diff handle?
Thanks
https://www.sau.com.au/forums/topic/449854-r33-s2-build/#findComment-7413885
The stock viscous LSD is a piece of shit and the sooner you find a Sims bin for it the happier you will be.
There is no confusion over diffs. You want to even think about putting 500-600HP you're talking a 2 way mech diff. Doesn't really matter which brand, although there are little differences between them that would perhaps make you choose one over the others.
https://www.sau.com.au/forums/topic/449854-r33-s2-build/#findComment-7413889
For drags a one way is fine, just make sure it is a proper machanical LSD
Without trying to start a GTR v GTS-t debate, they are two very different cars and what you learn about a GTS-t won't necessarily apply to a GTR and vise versa
This really comes down to how far you want to go into drag racing cause anything upto an auto GTS-t on slicks the GTR is winning
I've seen people spend more money and have more issues buying and building a GTS-t to run the same times a stock GTR with simple boltons will run
Have a look in the Motorsport build section for 2RISMOs build, that will give you some good info
https://www.sau.com.au/forums/topic/449854-r33-s2-build/#findComment-7414082
Ok so basically the stock diff needs to go. Thanks for that.
Where would I get a 2 way diff setup in perth?
buy one off the internats.. then take out your entire diff.. bring it to a diff specialist to fit your diff centre.. go home, break it in (according to the instructions) and then rip skids.
https://www.sau.com.au/forums/topic/449854-r33-s2-build/#findComment-7415859
    • Starting with issues 1 - 5, we have already run into a problem...!  Issue #4 contained 2x front brake calipers, instead of 1 caliper and 1x steering knuckle. Will have to call DeAgostini on Monday to sort it out. Anyway here's some photos.  Issue #1 is the front bumper, headlights and number plate. Issue #2 is the front wheel (with "We produced with spartan air." text on the centre cap!) and tyre, the front lip spoiler and cylinder head cover with ignition coils under the centre cover... which will never be seen again. Issue #3 is the bonnet and cylinder head. Issue #4 is the front strut, brake disc (with laser etched metal discs) and brake caliper. I stopped here because of the issue with the missing steering knuckle.  Next update will be #5 - #10 in a few weeks.
    • DeAgostini is one of a few companies that release quite large (the largest commonly available size actually) 1/8 scale models in a series of weekly issues over 100 - 110 instalments.  They release different models for different markets and DeAgostini Japan have release the BNR32 Skyline GT-R Nismo last month. I've made two of these 1/8 scale sized cars (one an R35 GT-R from 2012 - 2014, the other I'm just about halfway through, a BNR34 Skyline GT-R from the 2Fast 2Furious movie) so when this R32 was announced there was no way I could ignore it as it's my favourite out of all Nissans.  Each issue costs around $20 so it costs about $2.2K when completed. I suppose it is very expensive for what it is, but the quality and details are really very good, and there are many "gimmicks" like fully functioning exterior and interior lights operated with a remote control, working steering, all doors/bonnet/boot/fuel lid open and close, the side mirrors fold in and it even has a speaker for the engine revving sounds when you turn the lights on.  Each issue comes with a magazine that tells the story of the BNR32 Skyline GT-R Nismo from the first design stages of the BNR32 to Group A homologation and the various racing version that were run in the Japanese Group A and JGTC, and Australian Group A.  So I plan to update the build in this thread 5 issues at a time.  https://deagostini.jp/r32/?srsltid=AfmBOooKjxDc4EUK2rmXqMBPgyHfFJ24s4oEPJBNpnF-lFlsRoW0PE6P
    • As per title.. has anyone used so far? Keen to hear results, comparisons. In the market for a new mani for my new turbo. Any issues cracking?
    • Re read everything that has been written about this in this thread.. Let us know if you're still confused.
    • This would be a new pump with new gears. I'm just unclear on whether it's a good idea to run more oil pump flow if you don't actually need said flow. Oil level is set a minute or so after shutting off a warm engine so wouldn't the high RPM oil level in the sump end up lower all things equal? Plan is OEM clearances, main concern in my mind is whether the OEM pump can keep up with the flow requirements of any additional oil coolers.
