Hey guys. up for sale is my 1996 R33 GTST. 137thou on the odo.
I've only owned this for about 3 months, and only reason I'm selling is because I miss driving a Subaru.
Car starts and runs great. has a small leak from the passenger side tappet cover.
car was imported in August 2004
$9k ono
loc. newcastle
Fully adjustable Cusco coilovers
HDI Boost controller w/ gauge
BEE*R rev limiter
dildo shifter
front strut brace
aftermarket cd player sub/ amp
sparco deep dish with quick release
3 inch tbe with seperate waste on dump
HKS premium cannon
pod filter with cover
lenso 17x9 +17 all round. 215/45's all round
Adjustable front caster
hicas lockout kit giving adjustable rear toe
locked diff
gfb atmo bov
have the standard GTST wing but i've taken it off
has a front mount but not plumbed up yet
Running 14psi making 185-190 kw
10451698_296415337225306_289921387870615
10557708_290741817792658_172489600174706
10559719_261478777385629_378309338978104
Located in NEWCASTLE NSW.
text's only please.
0409840683
Edited by mattyboy33
https://www.sau.com.au/forums/topic/449866-fs-96-r33-gtst-nsw/
    • I used the radium thing, makes the whole parallel assembly a lot more compact compared to any other way of doing it
    • Racetronix also sells those ethanol content sensor bypass blocks. Adapter, Flex-Fuel E85 Sensor High-Flow Bypass, In-line No Sensor (ADF-FLEX-NS): Adapters - Flex Fuel | Racetronix Ethanol content sensor are originally designed to be on the feed line. These bypass blocks are meant to be ran in the feed line and not return. The continental ethanol content sensors have a 3/8" ID and not 5/16". This is why they are ran on the return line directly in conjunction with a low threshold sampling value VS in the feed with one of these blocks.    Haha we think alike, I used both original feed/return for 8AN feed, and one of the Hicas lines as a 6AN return. I also capped off and left the other Hicas line as a spare.
    • Interesting, I haven't read about the issue with oil getting into the speedo in the cluster before. I'll have to take more notice with mine. The speedo on my R32's when I've run factory diff and tyre size have never been accurate as far as I can remember. The non Type-M GTS-t did come with 15" 5 stud wheels and smaller brakes, but that's less than 5% of them.
    • Good to hear the condenser you picked up off my brother worked all good. Do you think there could be an issue with your AC compressor itself or the clutch on it then? I don't know a lot about them so I can't really help but keen to hear what it ends up being. Keep the build thread going man, it's nice to look back on over time.
    • This is a story of my life things, I learned eventually (thanks to someone calling me out) that my enthusiasm for discussing and sharing ideas that it came across as arrogance and I'm like... WTF?!    One thing I'm pretty sure I justifiably pride myself on is knowing that everyone will have things they can teach you, and you're always going to find out that something you think you know turns out wrong - you just don't know what it is until you get there.   Just the bursting enthusiasm that comes with ADHD when you hit something that gives you dopamine dumps can come across like you think everyone else is wrong or don't matter. But yeah, I'm a software engineer by trade and also do tuning in weekends and 100% have long had a reputation for  quickly making connections when resolving problems or forming solutions that I've sometimes had to take people form a long walk from start to end to explain how I ended up where I did when it's seemed "too simple" when I've stated my initial case, and had the "WTF" type reaction when they've realised how much was actually considered haha.   My reward is that I get all the curly problems thrown at me.
