Sadly the car has been written off by insurance. Below are the items which arent standard from a factory R33 GTR. Everything was bought brand new other than the ECU
1) Nismo Fuel Pump and full major service done with N1 water pump at 90,000km+, Currently 125,000km+
2) TE3718x9.5 +12 265/35/18 Michelin PS2 Porsche (tyres bought less than 10,000km ago and rims 2 yrs ago)
3) N1 Engine and N1 turbos
4) N1 19 rows oil cooler
5) N1 oil pump
6) Tein Super Street Coilover at 80,000km+
7) Project MU SCR Rotors front and rear at 90,000km+
8) Stock Brembo with Nismo R Tune pads at 90,000km+
9) Clear front and side indicators
10) ERD rebuilt gearbox with Nismo Coppermix Twinplate at 100,000km+
11) Apexi PFC and boost controller kit
12) Factory carbon wing
13) Trust Ti-R catback titanium exhaust (slightly blunted as per photo but can be cut)
14) HEL braided brake and clutch lines at 80,000km+
15) Engine seal at and engine mounts 100,000km+
16) Iridium spark plugs at 110,000km+
The parts of the whole car would be worth way more or you could just buy the car and repair it yourself. The attached zip folder contains all the photos. This is a genuine N1 with Nissan FAST verification. $9k for the whole wreck pick up in Brisbane. This will need to go ASAP.
fwdphotos.zip
https://www.sau.com.au/forums/topic/449972-r33-gtr-v-spec-n1-wreck/
Congratulations to the buyer :)
If he'd like to PM me about insurance, I'm happy to offer info within the scope of what I know.
And...
All the best to you Brandon...
Sorry to see her go I bet?
I'll update you when its all finalised. Its either going to a close mate that helped me do a lot of the work on the car or I'll use this as an opportunity to fix all the problem which you were going to if you got it if its financial within my limit.
I hate to let it go after this mate of mine reminded me how much effort and time I've spent on her. And my wife telling me its our wedding car. Lol.
Still waiting for quote from the panel beater and some parts from supplier. If the cost is within limits maybe its a good opportunity to restore the entire car. I'll create another thread detailing all the work if it goes that way.
If not, it'll end up with my mate and he will restore it himself since he's a mechanic by trade.
Biltz: You can close/lock this thread if you wish.
Edited by Brandon
    • A few more recent pics
    • full send the cnut, do this   fark the wrapping and/or stick on siet. These guys are the ones to go to: https://www.realthermo.com.au/
    • Just had a look, they don't. Fuelling on the base map is purely alpha-N, and the ignition table is MAP. Remember it's just a base map to get the car moving
    • Hi everyone, I’m Dave from Canberra. Here's a few pics of my 1992 R32 GTST coupe which I imported back in 2006. Only mods so far are HKS Hi-power cat back exhaust, K&N filter, ATC Volanti steering wheel, Pioneer stereo, amp and sub. This was my daily driver up until 2015 and sadly hasn’t been driven at all in the last 5 years due to marriage, work, and kids taking up most of my time and spare cash.As such its in need of a bit of TLC and one of my goals for this year is to get it back to running condition and maybe look into club/historic rego. I’ve joined SAU so I can ask a few questions along the way (although I promise to google Current Problem +SAU beforehand!)
    • From talking to the mx5 guys the NC doesn't actually need bonnet vents like the earlier NA and NB models, due to a better designed cooling system and undertray design There's plenty of them used as street cars and weekend track toys running anywhere from around 170 to 250kw with stock non vented bonnets, I initially was going to get some bonnet vents, but, as they are not actually required, I'll put vents on hold for a while and just monitor temps, though I do need to get something to actually monitor engine oil temps though, coolant temp can be pulled from the OBD2, but the oil gauge in the car is not actual oil temp, it is only a calculation based off coolant temp and RPM ☹️ They do recommend upgrading the radiator, which I have already done with a triple pass, and the only other thing they recommend for a street car is heat management, like I talked about above to protect bits in the engine bay from radiant heat, and to either replace the nearly 20 year old plastic coolant expansion tank, which I have done, or get a aftermarket alloy jobbie for some bling They did also say that if I wanted to track the car on occasion a oil cooler and sump baffle would be required, and as I already have had a sump baffle installed when the engine was out......... I'm going to get a oil cooler with a thermostat....... just in case I do eventually track the car, but probably not, but still maybe...🤪
