I'm chasing after abit of info on some rear lsd diff choices for my GTR 32 I'm running standard gear ratios front and rear, and the standard rear lsd. my front diff is a quaife helical. But I was wonder weather to run the standard lsd, 1.5 or 2 way in the rear, the reason I ask is that I've found a 2way pretty cheap but I don't want to just rush in and buy it without any advice. the car will be used for track/club days, drag racing and some street use. Any help or advice is greatly appreciated as I don't no much about diffs . Cheers
https://www.sau.com.au/forums/topic/450020-lsd-diff-choice/
Mainly track days and drags , powercruise etc I'm running the car on drummed e85 because tas only has one e85 pump in hobart. I had a bit of a search I was wondering who has used what kind of setups, like a helical front diff and a 2way rear wondering if they are a good or bad together, I was also reading about the transfer case mod with the extra plates, might be the go whist the motor is out.
https://www.sau.com.au/forums/topic/450020-lsd-diff-choice/#findComment-7414508
  • 3 weeks later...
32 GTR comes with a 2 way mechanical diff stock, you don't need a new centre.
If you want a tighter centre (or if you prefer, a "Nismo" rear diff), just have a diff shop add some more clutch plates
https://www.sau.com.au/forums/topic/450020-lsd-diff-choice/#findComment-7424644
While I am here I will take a chance of being shot down, I had some info that my R34GTR has a Nismo 2-way LSD but it does not clunk or bonk, chatter or clatter when going slowly on lock.
It was on a work sheet for the car before I bought it, is it possible that it is still a Nismo 2-Way LSD????
Can you tell by looking at the outside of the casing????
Edited by TT350GT
https://www.sau.com.au/forums/topic/450020-lsd-diff-choice/#findComment-7426730
As I understand it the 2 way locks up on acceleration and deceleration and the 1.5 on acceleration and 50% as much on deceleration.
It has been said that the 2 way is very clunky at low speed on lock, what makes the 2 way more clunky than a 1.5 way, the 1.5 still fully locks on acceleration, why would it be any different, maybe in reverse ??
Edited by TT350GT
https://www.sau.com.au/forums/topic/450020-lsd-diff-choice/#findComment-7426746
No, you misunderstand the differences and the behaviours.
1 way only limits slip (there is no such thing as "lock") when under accel.
1.5 way limits slip on accel and partially (ie, to a lesser degree) on decel.
2 way limits slip fairly equally on both accel and decel.
If the breakaway torque (ie, how tight the diff is) is set quite high, then a 2 way will be nasty to drive around in carparks and the like because it will behave as if it is locked. If the breakaway torque is set at a lower level then you can generally get a 2 way to cruise around without being too painful. A 1 way will almost always be OK to idle around in carparks because you don't have much drive power on. So you're not accelerating and therefore not engaging the ramps that apply the clutches.
The standard R3x GTR diff is a 2 way anyway. A Nismo diff is essentially the same thing just with higher breakaway torque setting.
https://www.sau.com.au/forums/topic/450020-lsd-diff-choice/#findComment-7426778
    • yeah i agree paint match stops it from standing out so much, oh that's actually really good to know i was wondering if it would help with air flow now actually having an outlet in the bonnet. Will have to focus on ducting into and out of the radiator now to make the most of it.
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
