Maybe, BUT it has only been 19 weeks, give them a chance, they have long lunches :cheers:
Oh, late start and a siesta after lunch, givem a break they can only work 1 hour a day :thumbsup:
Now they are just teasing you, haha. Just be happy when you get it back it all works and you have no issues with it I rekon. Also I think your number plate would look better back in the stock location.
How much longer did they say till its tuned and ready for pickup? Should be a real beast with the 3.2 :)
Hope you are wrong Mick,lol
I have seen number plates blocking half of the grill, not only that, a lot of blokes have their cars looking great and it looks like they nailed the plates on the front, but this is a personal choice, I like it there out of the way, that's why I got the thinner style. I am pretty sure that plate does not fit into the stock location.
Looking at about a week, so maybe the end of next week, but who knows. Then have to get the kids looked after and go to Sydney to get it.
As for the power, not pushing for high power, just response for a DD, I doubt if it will be much over 400awkw, it was 345awkw before the build
I am looking forward to see how the drive train works in together. it will be, Coppermix twin C Spec clutch, slave cylinder, Quaif front diff, trannie modified and going into the Nismo 2-way LSD. :woot: It has to drive better with the twin instead of the quad clutch as a DD :yes:
It will not take too long for the final tune as the drive home is about 350Klms and I will do it ASAP and get it over with and hopefully never have to do anything else to the car :)
  • Like 1
Would want to farken hope they know!!!
Me too, when you have this type of work done you would think the builder would know what compression ratio he is going with, I hope :/
Bets on how long the getrag lasts? :P
I dont think you quite know what you have built here Pete at 345kw that 6262 was barely passing wind. I think you can expect another 100kw out of this thing (with E85). It will probably make 345kw at around 4500 lol!
On that note is it being flex tuned?
yeah Mick, I already have the Haltech ECU and flex fuel sensor going in .
Getrag, are you the voice of DOOM , put me down for a $100 on 3 weeks, if I just hit 3rd slowly with soft hands, maybe 3 months , LOL
345kw @ 4500, laggy heap of shit!
I am sure I will scare myself,I think I have done that with every car I have owned, some lucky to get to 80mph but they could scare the crap out of you just trying to stop them :w00t:
Nice pics Pete, but how's YOUR engine going? :unsure:
CR will be like my cam specs, closely guarded secret :rolleyes:
So they never told you your CR when they built your motor, that is weird I think, if you pay for something you should get all of the info on your build, well should ?
So I will have cams that are a secret and a CR that is a secret, getting scared :bomb_ie:
    • I figured out what’s wrong. It’s something to do with the high beam wire short circuiting. When I measure the continuity with a multimeter on the headlight socket connector it gives me a continuous beeping noise when I put it on the ground socket and also on the high beam socket.  On the passenger side of the car (working side), it’s only beeping when the probe is on the ground socket. Which makes sense.  So that means it has something to do with the high beam power supply for the drivers side. How do I trace that? Is it the turn signal lever malfunctioning? The one that also controls the high beam and low beams.
    • Hey lads just finished tidying up a gtr a bought. Originally from Sydney now living in New Zealand
    • Hi Guys, Looking for this piece if anyone can help out.   https://tfaspeed.com/products/nissan-skyline-r33-gtr-rear-trunk-finsher-panel
    • How did you go with your problem? End up fixing it. Have a y34 aswell vq30det
    • But if I smoke test 5th cylinder it’s all ok, no leaks  when I try with 2nd it’s leaking exhaust and intake, it doesn’t come from oil dip stick.    so maybe when car was running poorly, rich or sth. Spark plugs were black and covered in charcoal or sth lookalike. could potential contamination make valves not seal properly? is there also a possibility that rb’s don’t have equal performing cooling passages  meaning back of the engine will be hotter than front. Can this cause improper wear if engine was running under load for short time? Or carbon build up could just burnt from 4-6 and is still on 1-3?   I out of my head like really. Timing is as manual crank-exhaust 47, exhaust-intake 38 at this point I thinking about give it a try and make another 500-1000km and check if anything change, if not I will most likely disassemble engine head /or whole engine and send it back to rebuild. It’s killing me
