I'd say 5 months is probably ahead of time on a build like this by a professional workshop....
There will be a month or more of a bit of back and forth once delivered to sort any small issues, run in and re-tune etc.
... it's better not to hope for a number on a page, regardless of what the car makes on that dyno on that day on that fuel your allways just a little dissaponted.
... these days I just rock up and go 'it make what it makes'
Cheers
J.
Your right Justin, it will make what it makes, as long as I get the feeling I am after, the numbers are just a point of reference. Shit I went from the 338awkw to 345 after changing the cams and turbo and it was soooo much better than the 7awkw indicated :)
As for the 5 months, I had all of the parts in the shop 2 months before I dropped the car off :)
Hi Mick, had some wires cook near the turbo while tuning it, fixing that tomorrow.
I struggle reading dynos as there are so many different types , some look like they shoot up and others like a slight incline but similar in results?, but the real test is driving the sucker home , even on low boost it will give me an idea. How did the Dyno look to you for the first run ??
They will be driving the car for a couple of days to make sure it is all going as the expected. Hope they do not smash it :spank:
Maybe ready on Wednesday or Thursday but it is not so easy to get down to Sydney from here as they have cut some flights and the plane gets booked quickly ?
But , not long now and going to start having some fun with this thing below :cheers:
Great t hear its nearly ready.
I really hope it is what you are after Pete, I can't help thinking that a supercharged v8 would fill your needs much better, but I'm sure you'll have a blast in the new combo.
I also know you will keep us up yo date with your thoughts!
Yeah its been a while :/
I am reasonably sure it will be what I want, I could have bought a new GTR or a BIG V8 and I am sure I would have like both BUT I wanted to go this way, just did not do my homework, suffered for my impulse buy and believing a car salesman , LOL
After the work I did before this , it was very close to what I wanted and being a stubborn little prick, I went the next step and gave it an extra .6Lt hoping it will spool 1000rpms quicker and the extra torque to get it moving a little better before the air kicks in. With everything , cams etc set for response on the final tune, it should be enough to shut me up and stop annoying you blokes.
I also wanted a car that no one really knows how it goes, not lowered, not lumpy and pretty quiet with an old fart driving, perfect sleeper :woot:
Its going to be awesome. No doubt about it.
The only thing where I think I might have gone overboard with, is the drive train, I doubt if I will ever truly get any benefit from the mods. But it seemed to make it a better all round car, shit then brakes and suspension but that can be done here, if I get the bug :yes::no::yes::no: oh F!
Jim said
If the dyno graph is anything to go by , looks and feels really punchy down low on the dyno and is happy to rev to 7500 - 8000 rpm up top with power.
First run in tune set up for running in purposes only .
The cam timing will be done at the same time as the final tune.
I really don’t want to be running the car for extended periods of time at high rpm yet till the vehicle has done at least 1500km running in time.
So :)
  • Like 1
Pick it up tomorrow, should be an interesting 350Klm drive home , run back on the old Pacific Hwy so I am not stuck on the same revs and give it a little work ..
Worried about the signs
Tomorrow is Friday the 13th :devil: and the last 3 numbers on the invoice 666 :devil: and I have to fly down :woot:
Good thing I am not superstitious , LOL
    • I'm hoping I just don't have to do an engine rebuild NOW. Doesn't mean I won't do it at some point. I think a plus point is that the car presumably ran on or close to stock power nearly all it's life so far. Only the Owner I bought it from actually increased power with a standalone ECU and blew the OEM turbos. And after it got thee 2860s it wasn't driven an awful lot either.   That is what I meant. With the twins coming on so late (4500-5000rpm) I hope the rods won't want to exit the block prematurely. And it still being a 26 means the torque curve isn't gonna hike up all that much.   It didn't blow up on the dyno when they tuned it to 500ish crank. So I suppose it'll be okay for now. They did put a Tomei head gasket on first though which did not seal at all, and they redid it with a Cometic one. Which I hope won't be my water leak.   Mainly anything oil. So far all it has is the N1 pump, oil restrictor and a filter relocation kit with a cooler.
    • 15000? ish? Something like that anyway. It wasn;t so much a wear as a tear that then spread. Might have lasted a lot longer if not bothered by just one incident, whatever it was. I took a punt. They are really comfortable and do a good job of holding. My daughter HATED it when I first put them in, and probably still does now. She has sensory issues and hates the way they are all up your business. I'm 197cm and 95kg. Not fat or particularly wide, and the XL size seat is the rigth fit. If I was any fatter it would start to get too snug. Any skinnier and you'd possibly want the smaller width.
    • Mrs rs focus came factory with recaro cs  sportsters in it and they a pain in the ass to get in and out of with the really high bolsters, once you were in them they were one of the most comfortable seats I have ever sat in
    • The NA 2.5 has very little torque. You won't feel much. Those trannies are also a million years old now and it could well be f**ked. First generation electronically controlled autos will often refuse to kick down, ete, etc, depending on what's wrong with them.
    • Yes, but no but yes but no. Those "it's fine up to 500HP" rules and everything else like it were all determined back when the cars were 10 years old. As they are now 30 years old.....what do you reckon the chances of something shitting the bed are? I'd say they are much higher now than they used to be. You might be lucky. You might be unlucky. Spin the wheel and find out. Yeah, nah. It's actually exactly the opposite. Making boost early and having heaps of torque able to be generated right in the middle of the rev range will do more to damage an engine than having to rev it high to make the power. Think about the load on the conrods, bearings, etc, to make 400HP at 4000 rpm, vs 400 HP at 6500 rpm. So someone has already "let the Nissan out" which is how we describe the increased chance of a fiddled with engine to have had something done wrongly. Many more engines that have been opened die than stock ones do - even if you into consideration how they are treated wrt power levels and the like. Again, not saying that yours will definitely have been put back together by a moron. But the possibility does exist. It's still a lottery. Spin the wheel. What weakspots?
