Taking less water, sounds more like an air lock.
Keep an eye on level and gauges, as you're doing, and you shouldn't have any problems (even if there is a slight leak).
Not sure if it is loosing less water, the time it seemed full after 50 klms I had opened it after about 5 minutes of driving it and it seemed OK, but the next morning it was down about 100ml, so it seems pretty constant :/ There was good pressure in the radiator when it was hot.
Jim did not seem too worried about it and said to keep an eye on it. So now I have a couple of Lts in the car just in case and to keep it topped up. I do it now after it gets cold to get a true reading.
I think any air pockets would be long gone by now, but I think as long as the lose of water is constant over a given distance driven, seems to say it is not getting any worse "I hope"
Only have a couple of weeks before the final tune, this will give them a chance to test and find out where the water is going and fix it :)
Nothing unusual, bit of aircon dribble .
100ml over 60 klms is reasonably slow considering it has pressure I think, but??
Wish it had green coolant, much easier to spot :)
Not sure on RB26, but on my 25, the turbo coolant feed line runs round the back between the head and firewall, that's a good spot to have a slow leak, maybe have a look in there.
The only water I can find is ,I think from the aircaon and it is coming down where it always has before the build. It drips down at the back of the front wheel , in where the connection is to the exhaust where the pipe comes down from the motor when you stop the car, does not smell like radiator water and if it was leaking like that all the time the radiator would be empty after 100 or 200klm.
I think I can smell it coming through the aircon. There are no wet areas inside the car.
Only have a couple of weeks to go and they can find it, it is a wonder they did not see it while they were using it, maybe they did and that was why they told me to keep an eye on it to see what happened ??
my old man had a coolant lose in a commodore, using half a litre a week (500km's), it turn out to be a small, 8 mm hose at the back of the motor, was only a slow drip and wasn't evident because it was near the exhaust, so it burnt off as it dripped,( only one drop every 10seconds) just was thinking the turbo coolant line is that size and hidden at the firewall, so thought id suggest shining a light in there. the smell could be coming thru the firewall round there..
Edited by AngryRB
the water from the ac is normal.
Ac removes the condensation in the air.
It is possible to have a leak in the heater core, that won't initially come out, but will after enough leaks into the system.
You would think if it was loosing water under pressure it would still leave a puddle after the motor is turned off, but it may be similar to your old mans car.
After a drive tomorrow I will have a look before I turn it off.
I hope it is something simple and no need for anything drastic , but as there is no oil in the water and no water in the oil it should be OK :/
Yeah water always comes out of the AC with the cold air on.
How much is enough before it comes out, has to be a couple of Lts missing by now
The only good thing about this, Jim is not worried. So I will worry for the both of us :)
If going onto the exhaust, it would evaporate.
By the time the exhaust cools down, the cooling system has dropped pressure and stopped leaking.
the aircon water does not evaporate, but it only hits the pipe low down near the bend on the way down and warms up before hitting the ground
5-10 minutes after you shut the car off after a good drive is when you look for leaks on the ground as the pressure builds once the car is turned off and the coolant heats up due to it not moving through radiator
This happened to me when i put my motor back in and it was a hose clamp on one of the 8mm hoses under the brake booster wasn't on properly :(
I will give it a good going over today after my drive today, thanks
My major problem is my lack of knowledge about these cars, well car internals in general and my body being stuffed makes it difficult to get in and around them to search for things like this :(
When I was young you could get inside the engine bay and there were only mechanical problems, no computers etc, now you are lucky to get your arm in there, lol
But I will see what I can see
Workshop can put a pressure tester on the cooling system and see if it is actually losing pressure - makes it easier to spot leaks if they exist.
Yeah Bob , as they do not seem worried they will do it when I take it down in a couple of weeks, have the Klms up now for the final tune and I would rather that they do it and no one else can be blamed if shit happens.
I am keeping a very close eye on the oil and water while driving and after each drive and all good , well except for loosing water , LOL
That's how i found exactly where my leak was, i pressurised the system and bingo
  • Like 1
Just did 126 Klms, parked for 10 minutes and could not see anything leaking. Drove into the garage and apart from the aircon water there was one dribble about 2 foot in front of the aircon water, I think it could have been some of the aircon water that dropped after I drove off.
I let the car run for a while longer, turned it off again for a while and then moved the car out of the garage but other than the aircon water there was nothing, I thought I found it for a minute :(
When it cools down later I will see how much water it takes.
Got all of the Klms done for the tune, just a drive to Sydney away in 2 weeks and :cool:
Nice.
Try putting windows down and turning ac off 10mins before you know you'll be home.
She I understand stop the water from the ac coming into the equation.
I did turn the aircon off once before to test it, but I had it on for a long time before that , so I will turn it off from the start and try again, love to find the leak.
Might leave it off for a couple of days just to be sure.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
    • If you are keen, have a look at my build thread. Car is for sale for the right money or straight swap for a F80 M3 LCI.
    • Welcome mate.  No point in over thinking it, buying any one of those cars you mentioned is not a smart or logical choice with the availability of many "better" (re price to performance) cars available to you.  The heart wants what the heart wants, buy whatever it leads you too.
    • Hey everyone! Im so grateful to be apart of this community and ill do my best to be apart of this. Firstly, i'm not disclosing my real name due to in real life circumstances surrounding my privacy and public image (sorry lol) Secondly, The only thing personal I am willing to share is that I'm from Sydney and a descendant of one of Sydneys largest mortgage firms. I got gifted my first ever car, a 2022 Porsche Cayenne and I love it to death. Ive been driving it for about 5 or 6 months now and honestly Im so grateful for my parents for gifting me this vehicle. However recently I've been working my ass off to afford my second car (which I need help deciding soooooo community help me out please?). Once decided, im planning to try modify it myself. Recent I've been thinking about getting a Skyline, particularly a 25GT or GT-V, yes I know overrated as hell, but I'm also considering a Chaser which I recently came to love. However my dream is to one day own a 180SX (So hard to find clean versions and im not really into importing).  Lastly before I send this off, I want to apologize if I sound tacky or pretentious. I try not to and want to genuinely learn from everyone and anyone. (Im no expert in this area) Thanks for reading!
    • I've got three stashed away but it's starting to get silly with the prices
