No Frigan way, lol on my single set up yea maybe.. Not with twins
Costs you more to do an engine by the time you refill coolant, power steering, front diff too
Actually I take that back... Not even with a single
Says the bloke building a 3.2 L. :D
Oh shit, beeeeen soooooo long I forgot about that and I was just getting used of the awesome power of the Tiida on 98 pump :)
Just been told the motor is complete and they are modifying the sump to suit the RB30 all wheel drive conversion, whatever that means :)
They bloody well should have from factory. Fairy ass 2.6 junk
Rb 30s don't have an awd sump
maybe thats why they are modifying it?
I do have a 9Lt sump on the car.
Ahh yes.. I forgot about that..
Please tell me your getting your old engine and head back?
getting everything back , I will need a truck to pick up all of the leftovers :(
Edited by Nismo 3.2ish
took me less time doing the engine swap leaving the box in then taking it out
We don't build em to drive them around the car park :P
Pretty true mate, I was going to buy a new GTR but I did not have a feeling for them, saw the R34GTR and bought it , untuned and still had 1000 Klms to run it in. Unfortunately it was nothing like the Lees said it would be once it had the final tune, peaky 338awkw and crap as a DD.
Had to make my mind up what to do with it, modify it so it drives the way I want or piss it off. I tried a few mods that worked OK but still to weak until 3500rpm. the only way I could see how to get it firing up from the get-go was a stroker, maybe I went too far with the Nitto 3.2 but I figured more is better than less for what I want and the right foot or boost controller can take care of the extra power if I do not want to use it.
Might try some Hill Climbs and a few Mugs day at EC??
Have a look at it, how could I sell it, A GTR Skyline and like anything, if you like it, you like it!
  • Like 1
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
