Hey all selling my old ecu out of my R33 GTST,due to upgrading to better engine management,seeing as i am running E85 now,and my car is making way over 400rwkw,can plug into anything,but has 32,33,34,factory plug wired up alrerady,3 bar map sensor,was making 330-340rwkw with no hassles,can ring the tuner if like.....asking $500 but negotiable,need to make coin back to pay tuner for my car....cheers mick 0420845127 (tried loading images,but saying files are to big to upload,will be quiet happy to text you photo's etc).
    • Holy hell! That is absolutely stunning! Great work!!!
    • It does when you start adding everything else in. But it's not just compute. It's the logic. Getting your timing right (I'm not meaning ignition timing for the engine). Making sure of your memory mappings, seeing your interrupts. Microcontroller devices only have so much capacity. For the most part, you want all those timers and interrupts in use on your engine control, which means you're left with less than ideal methods for timing and management of other control functions.   Let's put it this way, my job is all about building custom hardware, that goes into cars, and integrates with them. We're also waiting on a media confirmation from SpaceX too fora world first we've just completed with them in NZ too. It's not just the little toys I play with. But you know, you can think and believe what you want.
    • I don't think it's a good buy, the trend looks bad     lol.
