Hi all,
We've recently bought a m35 stagea which came with tein coilovers.
Given that this is the family wagon, these coilovers are tricky to adjust for a nice ride, and may be due for a rebuild.
I would prefer to replace it with the stock axis or rs4 suspension, or preferably the nismo aftermarket shocks and springs.
Does anyone have any of the above for sale? Willing to pay for courier for the right parts.
Thanks
https://www.sau.com.au/forums/topic/450101-m35-stagea-suspension-change/
Hi all,
Thanks
Where are you located? I might be interested in a trade
Im in melbourne. Se suburbs specifically. What you got brick?
I am based in sydney so probably would be more Hassle then needs be.
My car has the factory upgrade suspension which sits 2" lower then stock but gives a really nice ride being the nissan upgrade set
Thanks all,
On this subject, which is the better option out of the nismo s tune and bc br coilovers?
Looking for a nice sporty ride with handling to suit. Not too firm, but not too mental either. This is the family wagon after all
Bc's. $1149 delivered in 2-5days.
S-tunes are the same price but you'll be waiting 2-3 weeks. I Don't know if they've changed them in the last couple of years, but the s-tunes in my r34 weren't height adjustable and didn't have the adjustable front tops.
  • 1 year later...
Hi folks, I realize this is an old thread, but I have just bought an 04 ARX and it has leaking shocks. What options do I have in coil over or even performance air ride.. I'm wanting to maintain the ride height where I can, but stiffen up the lateral movement with sway bars and braces.. I'm hoping I'm not too late to the party and look forward to learning more and with any luck comparing notes :) cheers
Ive got a spare set of AR-X Bilstein shocks with King Springs. PM me if your interested
BC Coilovers, Tein Coilovers, HKS Coilovers, MCA Coilovers, Nismo S-tunes. .....
Spoke to JustJap re the BC's and they told me with the ARX, the wheels will sit just off the guards at their most extended point.
On the others, I can't seem to find anything on whether they are ARX compatible. I really don't want it lowered much at all, if any... difficult aren't I :-/
Sway bars from SuperPro make a HUGE difference
Agreed, fully intend on replacing the bars once I get the car and figure out all the bushes that I need to replace in the one job... hope I can stretch the purse strings lol
    • It was roughly 3.5 hours.    car went in around 11:00 and I was done around 2:30 He did the initial runs, install the BC and then Nistune install and tune.  The best part was sitting in the lobby and hearing the skyline on full throttle at the dyno 😂😂
    • Glad it all went smooth. How long did the tuning process take?
    • Yeah that was kind of the same feedback my tuner gave me.  the boost tee is until I can sort out my plan for the electronic boost controller and what I’d get, where I’d mount the dash etc.  I’m happy with this until I can figure it out. Not a big fan of the A-pillar gauges. I’d like to get a clean install of the boost gauge - something digital like GFB.  Something like that might fit neatly where the ashtray is and look clean. I feel like replacing the OEM triple gauge is a bit extreme for a weekender like my skyline. And it’s not making crazy power to need all the additional sensors/gauges.
    • I'm about to swap my box to Tremec T56 Magnum F & initially thinking of re-using my DCS twin plate (can get it re centred for the bigger spline) but it's been called out the box will be noisy (rattle) as the clutch is unsprung.  So I'm doing as much research as possible. I'm not so worried about holding the power as I'll go the track version which on paper will hold the maybe 1000hp I make. It's the longevity I worry about. DCS told me they don't use a sprung centre as it's just something that can break. The uni clutch has a very complicated sprung centre. Any one had or heard about any issues with it failing? Thanks in advance.
    • Auto is at least 10% (from my real, actual experience with different torque converters and manual on the same setup) ~185rwkw at 11.6psi (peak!) is entirely what one would expect without a FMIC or anything else on the intake, it does bleed off towards the higher RPM so it's what, 9psi there? Note: There is nothing that can be done about this with a manual boost tee. If you want to hold it steady and gain more top end, well - You will need electronic boost control.....
