Yeah definitely man. They are most likely on their way out. I was looking at MCA and heard good things about it. It is a bit pricey though, but they have been proven on the track. I'll keep an eye out for some second hand stuff atm and we'll see what happens.
A mate of mine got 8kg/8kg MCA Blue for his Evo7. With 245/40/18 Hankook RS3 rubber, the ride was unnaturally comfortable, almost standard-like. We drove through some rough roads that my GT-R would never be able to do at the speed his Evo went (like 50 km/h, really rough road). It was incredible.
Shows that a well dampened unit can use higher spring rates 'comfortably'.
And also.....you cannot compare spring rates between cars. Different suspension geometry means that there are different lever arm lengths working on the suspension unit. a 4kg spring on one car might be quite firm but be waaaaay too soft on another, simply because the second car has a longer lever working on it. Squishes the spring less, but can apply more force over that short distance.
Thats right. Which brings to the question, can you compare spring rates on the same model of cars. So can we safely compare spring rates among R33 GTSTs? Im guessing to a degree we can, but obviously the different setups guys run and different components they use and possibly allignment specs will have a bearing so it won't be a dead accurate comparison. Yay? Nay?
*damped*
Just sayin'
Thanks, didn't proof read (shifty typing at work :P).
Yeah I agree, but 8kg springs on any road going car should be noticeably stiffer compared to stock, no? I drove and rode in his car before the change, I changed the standard struts out my self on the weekend. Reference to my GT-R was to paint the condition of the road we went over, not to compare the two cars' handling.
Agree. Best way to compare is to ride in the car itself, which of course is pretty difficult.
Any 2 R33s (so long as not comparing GTST with GTR as the weight distribution is a complicating factor) can be compared spring rate for spring rate. Everything else in them is the same unless someone has significantly longer lower arms or the like.
That said - ARBs are a confounding factor that most people neglect when talking about this stuff. You cannot compare my car to one with 8kg coilovers if they only have stock ARBs. My ARBs probably contribute 50% of my roll stiffness and maybe 50% of my single wheel bump stiffness (if I could be bothered figuring it out). On the 8kg coilover car, that could be only 10%. Just to make up a believable random comparison.
Any 2 R33s (so long as not comparing GTST with GTR as the weight distribution is a complicating factor) can be compared spring rate for spring rate. Everything else in them is the same unless someone has significantly longer lower arms or the like. ...
Good to know, I always wondered about that. I once worked out that the stock springs are like 2.7kg/mm or something so all the Jap spec stuff at 10 or 12 kg/mm seem completely over the top. I also find it interesting how small the coilover spring diameter tends to be compared to the stockies, they're tiny...
Also great point about the swaybars, it seems that a lot of cheapie coilovers attempt to take on the job of the swaybar by upping the spring rate. Instead a lower spring rate + bigger swaybars is the better solution AFAIK. At least that's what I did :)
  • Like 1
So I was thinking of going something like this for now, for 'testing'. What do you guys think? Anyone know what spring rates these may be? Seller doesnt know.
http://www.ebay.com/itm/281478597591?item=281478597591&viewitem=&sspagename=ADME:X:RTQ:MOTORS:1123&vxp=mtr
Cheers
One last thing, how do I know if a set of coilovers has adjustable damper by looking at it?
Cheers again
Little adjustment knob, most likely on the top sometimes on the bottom. Google for pictures of BC coilovers to give yourself an idea.
The ones you have linked are damping adjustable by the look of it.
Edited by owen1r
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
    • I can donate $100 to your upgrade fund. So long as you can donate the IC7 my way....
    • I'd love a Haltech ECU, and Haltech 10 dash. Was having a chat with Rob and Andy @ Haltech when Rob put one in his MR2. First one I'm kind of interested in too, as you can dim it RIGHT down. Andy was saying bright dashes is one of his peeves too!
